Results 1 to 3 of 3
Thread: A/c Charge Question?
06-12-2007, 02:33 PM #1
- Nov 2006
- texas
red- 2001 formula
I just done some a/c work on my 2001 formula. I evacuated it and it held 28in vac with no leaks. Since I am relatively new with F bodies. The system took about 2 and 1/2 cans of r-134 and my pressures at idle with a/c on max hi blower were low side at 40 psi and high side about 240 psi and register temp with 92 degrees outside temp in the sun was about 56 degrees and driving the car temps came down to 47 degrees at max and high blower. Can I expect any better out of this system?
06-12-2007, 06:09 PM #2
outside temps affect the AC discharge temps. usually, you'll get about 20-30* lower than ambient temps. so, looks like it's right inline. getting the low side in the 30-35 psi range will lower the discharge temps a little more.
06-12-2007, 07:23 PM #3
- Sep 2006
- s.e. ma
primer- 65 nova
well said mrr23! 47* on a 92* day is cooool
XBOX 360 charge kit
By allbaugh_04 in forum Almost Anything GoesReplies: 10Last Post: 01-05-2010, 09:28 PM -
Murder charge
By Fung Bucko in forum Almost Anything GoesReplies: 6Last Post: 05-09-2009, 04:13 PM -
Why can't my car hold a charge???
By CWW17 in forum General HelpReplies: 17Last Post: 03-12-2008, 06:15 AM -
who to charge
By tonysz28 in forum Almost Anything GoesReplies: 32Last Post: 10-02-2007, 11:12 AM -
STS charge pipe
By MavrickCJH in forum Forced InductionReplies: 3Last Post: 11-15-2006, 02:15 AM
