Results 1 to 20 of 67
Thread: 03 Grand Am: oil in coolant
10-21-2010, 10:10 PM #1
- Jul 2006
- Greene, Iowa
Red- 99 Chevrolet Camaro Z-28
hey i am stumped on what could cause oil to get into the coolant of my wifes 2003 grand am gt with the 3400 v6...she took the car to get a simple oil change, and they checked all fluids for her, and found oil in the coolant reservoir...i asked if the car is acting up or what not, and she says the car runs a little hotter than normal, but nowhere near over heating. the service shop naturally wanted to charge her 100 for a coolant flush right there on the spot, but i told her to hold off until we get whats causing this to happen fixed. so any ideas on what would cause the oil to leak into the coolant...thankfuly its oil in the coolant, instead of coolant in the oil...i made sure of that. but at this point any information, or things to look at would be helpful
10-21-2010, 11:06 PM #2
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
Head gasket???
02 tahoe Z71 blacked out
98 z28 red m6 sold
07 zx6r ninja flat/black sold
08 zx6r ninja sold
10-21-2010, 11:14 PM #3
- Jul 2006
- Greene, Iowa
i dont know bout the h.g....it still runs good
10-21-2010, 11:20 PM #4
- Feb 2010
i will run good.. but after days will get hot.. and white smog out of the exhaust..
idk thats the only thing i can think of..
10-22-2010, 01:26 AM #5
Worse case, could be a cracked head.. I'd say check it yourself and see that there IS in fact oil in the rez (touch it does the substance feel like grease or mud?).. It could easily be sludge from an iron block motor.. Flush it and see if it returns.. Head gaskets are not really a common problem for the 6-60.. Change (goes to the possibility of sludge not oil) the thermostat too...
10-22-2010, 01:40 AM #6
10-22-2010, 05:22 AM #7
I agree with Smitty on this. I had the same issue on my 96 3800II a few times. It was just sludge. I flushed it and it was fine. I hope that's your issue.
10-22-2010, 07:44 AM #8
- Jul 2006
- Greene, Iowa
will this iron sludge cause the motor to run a little warmer than normal??
10-22-2010, 07:46 AM #9
- Jul 2006
- Greene, Iowa
any chance or possibility it could be lower intake gaskets? as thats what came up on google
10-22-2010, 08:56 AM #10
10-22-2010, 09:28 AM #11
10-22-2010, 09:43 AM #12
if there is oil in the coolant it could be the trans cooler in the radiator. headgaskets usaully will get coolant in the oil . also the lower intake gaskets can leak internally into the oil but again there would be coolant in the oil not the other way around. and fel pro makes an updated steel gasket with rubber around the sealing parts for the intake . they are the perma dry plus gaskets..
10-22-2010, 09:46 AM #13
3400 ohv lower intake gaskets..
These are the effected areas..
10-22-2010, 09:52 AM #14
yes but again when they leak there it ends up outside the engine or in the oil giving you that chocolate milkshake look
10-22-2010, 09:54 AM #15
Could be getting in when it's not running.. High 2-valve 660's bath the valve stem heads and springs in a pool of oil which then over flows the head and runs back into the motor right next to the coolant gasket jackets.. As the engine cools suction is created on the cooling system and could actually be "sucking" up oil pooled on and around the gasket itself..
But I'm leaning more towards iron sludge..Last edited by Smittro; 10-22-2010 at 10:00 AM.
10-22-2010, 09:58 AM #16
ok lets look at oil pressure . when the car is running the oil pressure is more than the pressure in the cooling system . now after the engine has been running and builds pressure in the system when you shut the car off it will bleed down into the engine
10-22-2010, 09:59 AM #17
but yes i would say do a coolant flush and see if it comes back .
10-22-2010, 10:03 AM #18
10-22-2010, 10:06 AM #19
10-22-2010, 10:07 AM #20
only had one do that but it was ran pretty long before they got it to me .
Help: Need pic of coolant pump weep hole (Coolant Leak)
By Sweet Chops in forum General HelpReplies: 13Last Post: 04-20-2009, 07:14 PM -
1975 Pontiac Grand Am - Grand Am Grand Slam
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 12-03-2007, 06:30 PM -
Loosing Radiator coolant and milky colored coolant... what to do?
By JehalinTA in forum General HelpReplies: 23Last Post: 06-19-2007, 07:28 AM -
Coolant light...coolant level full.
By SR71 in forum General HelpReplies: 4Last Post: 01-08-2007, 09:35 AM -
ls6 intake coolant plugs or extra front coolant pipe?
By mikes ss in forum External EngineReplies: 3Last Post: 12-03-2005, 04:13 PM
