Results 1 to 19 of 19
Thread: anyone know what this tool is?
07-17-2012, 05:57 AM #1
- Oct 2009
- The Woodlands/spring/houston
pewter- 99 trans am
a coworker found this at a flea market but dont know what it is...anyone?
The blade flips out and is a loose fit. It does not lock. It is not razor sharp, rather dull and crude in manufacturing.
07-17-2012, 06:42 AM #2
- Aug 2007
- Texas
my first thought was a plumb bob, but the blade throws me off....
prison shank?
07-17-2012, 10:25 AM #3
What does it say just under the "B" with the circle around it?
07-17-2012, 10:57 AM #4
http://home.comcast.net/~alloy-artif...ircle_logo.jpg
Is that what the "B" looks like? If so it is Bonney Forge & Tool Works
07-17-2012, 10:58 AM #5
- Nov 1999
- over here...
it's clearly a swiss butt plug...
07-17-2012, 11:28 AM #6
- Jun 2011
- Branchville, NJ
I think it is used in the leather cutting / crafting business.
07-17-2012, 11:32 AM #7
I think it's a Bung Auger.
looks very similar to these.
barrel bung auger | eBay
07-17-2012, 12:02 PM #8
I don't know what it is, but Spaz would stick it into a watermelon for sure.
07-17-2012, 12:13 PM #9
07-17-2012, 12:23 PM #10
- Oct 2009
pewter- 99 trans am
i found out what it is...its a cork borer sharpener.....https://www.google.com/search?hl=en&...Do_g8AT567znBw
it is used in laboratories to sharpen the cork borers for boring out rubber stoppers. You put the pointed end of the sharpener on the business end of the boring tool, then you pull the blade down and twist with a little pressure and there you have it.
07-17-2012, 12:26 PM #11
07-17-2012, 01:13 PM #12
I was close....
07-17-2012, 02:57 PM #13
07-17-2012, 03:34 PM #14
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
I bet I could kill a zombie with it......
07-17-2012, 05:53 PM #15
I thought it was for castrating sheep. The pointed end, of course, when slipped in surprises the hell out of the sheep and when it jumps up out of fright the blade cuts off the nuts. It's definitely used for volume castration where one cowpoke is working alone. Make sure you give that tool a steam cleaning prior to using it in your kitchen. Always glad to solve these hard to identify questions.
Magnaflow Quad Tip, Lid, SBellow
UMI: FTC, FSB, RSB, LCA's, PBAR, SFC's, T-Arm w/relo, D/S Loop
Kooks LTH, 3" YP, H/F Cats
Custom Grind Cam, Stall, 3:73 rear
Bilsteins w/Strano Springs Conti Super Contacts
TuneByFrost MSD Wires
Cross Drilled/Slotted Rotors w/Ceramic
07-18-2012, 05:11 AM #16
07-18-2012, 05:15 AM #17
- Nov 2006
- Broken Arrow, OK
It looks like a siggy to me
07-31-2012, 08:33 AM #18
07-31-2012, 10:14 AM #19
Tool
By 01ws6er in forum Multimedia SectionReplies: 4Last Post: 07-12-2008, 07:30 AM -
Okay...who is this tool???
By Mr. Luos in forum Almost Anything GoesReplies: 23Last Post: 03-05-2008, 09:29 PM -
tool box
By formergper in forum Rocky Mountain MembersReplies: 10Last Post: 04-03-2007, 06:43 PM -
need used tool box.
By Hi-Po in forum Almost Anything GoesReplies: 10Last Post: 02-08-2006, 07:19 PM -
gm ls1 tool kit fs
By closs2sx in forum ToolsReplies: 7Last Post: 01-03-2006, 06:29 PM
