Thread: Stroker's
    Senior Member OnEbAdReDSS's Avatar
    Puyallup
    2000 Camaro SS # 5,876
    Stroker's
    Soo i am planning on strokin the camaro to a 383... what needs to be done...
    Buy the Kit..
    Take engine out..
    Have engine shop work on engine for 383 Stroker...
    put together stroker...
    and such...
    anything else??
    Puyallup
    and oh ya i have built engines before including strokers... just not on a aluminum block..
    T/A Everyday oreowizard's Avatar
    Charlotte, NC
    blue
    98 T/A LS-1
    Im wanting to go stroker aswell. Either a 396 or a 383. Haven't made up my mind yet, whats the opinions of the group. Will be a DD, M6.
    Impounded MikeSomething's Avatar
    Old Bridge, NJ
    Pewter Metallic
    '00 Z/28
    What other MODs you got?
    Lemont, IL
    2002 Trans Am WS6
    I am curious too. I just retired the 02 WS6 last year to summer/weekend duties. I'm doing a gentle resto on it now and have plans to stroke the LS1 to a 383 within the next year or so. I'm more interested in recommendations on reputable speed shops to do the work and I want to start getting a ball park estimate on how much the setup is really going to cost me.
    I'd like to keep my current block for nostalgia, stroke the motor and run a fairly aggressive heads/cam setup on it. It's an A4 with just light bolt-ons right now. Looking for about 550hp at the crank. Anyone have any input?
    Thanks.
    Old Bridge, NJ
    Pewter Metallic
    '00 Z/28
    Quote Originally Posted by See Me In My GTP View Post
    Thanks.
    I would suggest more than "light bolt-ons"...
    Def gonna wanna let your car breathe better w/ aggressive heads & cam.
    Lemont, IL
    2002 Trans Am WS6
    Quote Originally Posted by MikeSomething View Post
    I understand...I was referring to the current setup I have. I have been saving to rebuild the motor, add headers and a torque converter all at once. The setup of the car now will have almost nothing in common with my future plans. I was hoping to get a better idea of what a typical 383 stroker setup costs on an LS1 motor and if anyone has had good experience with any shops. Thanks for the response though.
    Senior Member rajiv1998's Avatar
    New Jersey
    1998 Pontiac Trans Am
    Correct me if im wrong, but isnt 550ish to the cranks about 500ish to the wheels? If so, ur gonna need a hell of a H/C setup, or maybe stroke it out a bit more possibly 396. Stall, rearend, and gears are gonna eat up a lot of power but dont let it get to ya.
    Skip the 383.
    New Jersey
    Skip the 383.
    Word, if u wanna make 500 to the wheels all motor, ur gonna need more cubes. Start looking at 402,408,427 etc...
    Junior Member JGARZA54's Avatar
    DFW area
    1999 z28 camaro
    Hey guys hows it going? I'm actually doing the same thing to my ls1. I have done some research on this for sometime now.. If you have the same engine as I do, which is the 346 ls1 engine, the biggest stroker kit you can get would be the 382 or 383.. Ive seen lunati's stroker kit by far the most expensive than the other two that Ive look at. Eagle and scat ranging from about $1300- $2200 and $3200-$3800 for the lunati.. From the research I've done the 382 stroker is not a good investment unless you have a very very low mileage ls1 engine dont know why.. It is possible to go with a bigger stroker kit on this engine if you have the money of course by resleeving and of course finding a machine shop that has done this on an aluminum block. I have not made up my mind but Iam close and its between Eagle and Lunati. I'm sure there are others that do stroker kits so look around... The thing stopping me on these 2 kits is price and the saying "you get what you pay for" so I just might have to do a coin flip and hope all goes well.. The difference between my stroker kit and some of you alls is that I need low compression on my stroker engine since I will be going with an APS twin turbo setup... Well hope this helps some of you guys there are some links that guys give you in this forum if you search for ls1 stroker kits...
    DFW area
    1999 z28 camaro
  1. Question: 6.0 stroker
    By speeedo in forum Internal Engine
    Last Post: 03-19-2008, 01:43 AM
  2. Stroker q
    By grandkodiak in forum LT1
    Last Post: 02-28-2008, 08:53 PM
  3. Stroker kit on LS1?
    By Wheeler99WS6 in forum Internal Engine
    Last Post: 03-24-2007, 07:15 PM
