Results 1 to 20 of 134
Thread: How long has your LS1 lasted???
11-01-2010, 04:09 PM #1
- Nov 2010
- Rhode Island
Black- 2002 Camaro Z28
Hi guys, new to the fourm. I dreamed of the day I would be able to belong to this board, and the day has finally come. Just bought a 2002 Z28 with 135,000 miles on it. It was taken good care of though, looks really nice, very clean engine bay and car. Just wondering if 135,000 miles is high, anything I should be getting worried about at this point, how many miles do you guys have on yours? The engine runs great but I do notice a ticking sound when I have my driver's side window open...
11-01-2010, 04:22 PM #2
Anything over 100k is high mileage reguardless of comments to the contrary .. That's why the blue book goes to shit on cars over 100k.. Time for a rebuild imho..
11-01-2010, 04:36 PM #3
- Aug 2007
- Texas
a few guys on here have them over 200k, but most of us are in the 60-100k mark....im at 73k myself on the 2000 SS, and 97k on the 2001 3.8
11-01-2010, 06:14 PM #4
- Jul 2009
- North of the Motorcity
Just turned 70k here.
Probably wont have 100k on her for 5-6 years. That's assuming I don't have to do a shitload of work to my house again this summer.
11-01-2010, 06:20 PM #5
- May 2010
- Wilkes-Barre, PA
Black/Black- 98 WS6/04 Sierra Dmax
I spun a bearing at 69,xxx. I put a few hard miles on the stock motor.
11-01-2010, 06:32 PM #6
- Nov 2009
- NOVA
2002 C5 - M6 - Blue- 2000 Z28 - A4 - Pewter
I can't say "I have" these miles, as I didnt buy either one brand new...
but the Y2K has 125k and running damn good still
'99 has 165k, needs a PS pump, thats the only thing mechanically wrong with it, that I know of. It's been through one transmission atleast so far, but it's a B4C so I guess you could say it would be long overdue if it had not had one yet.
Both cars, at a warm idle, in gear (A4s) hold only 25psi or so of oil pressure. I don't like it much, but whatever. I've always been one to keep a constant eye on my gauges no matter what i'm driving.
As for the ticking, I know a good percentage of these cars do that. Especially after cam swaps. I've yet to do one myself, but I'm assuming it could be attributed to using OE pushrods and lifters in some instances I'm no expert, I'm sure someone else will chime in on this, just my two cents
2000 Z - Light Pewter Metallic - A4 - 130k - Bolt Ons - My Pride and Joy
2002 C5 - Electron Blue - M6 - 32k - My Dream Car
11-01-2010, 07:14 PM #7
110k, 2 trans, 4 rearends, on the second motor.... but the first motor did last for 3 years with a ms4 cam and a 150-200 shot shifting at 7k
11-01-2010, 07:53 PM #8
- Feb 2007
- San Diego, CA
The 02 is at 49,xxx. The 98 is at 181,xxx...
67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
Carbon footprint? CLOWN SHOE!
11-01-2010, 09:04 PM #9
Since this is the last season for my 01 till it's rebirth in the future it will likely never see more than 100k... Only thing left will be the unibody structure itself.. No exterior panel (think carbon copy) will be savaged.. Major changes (need to be) will be made to alot/most of the engineering of how it sits now.... Mechinically not a single piece will be reused.. Prolly not even have a Camaro drive train @ all or @ least no where near it's current setup.. But rest assured guys I have made up my mind.. I have given up on the 3800 idea all together.. Think DOHC v8..
The OP, Welcome! To LS1.com, it's what we do..Last edited by Smittro; 11-01-2010 at 09:12 PM.
11-01-2010, 11:38 PM #10
103,000, runs like a champ, beat on it all the time, prob need a new rear end sometime. m6.
11-02-2010, 03:46 AM #11
- Oct 2010
- covington,ga
white- 1998 z28
I have 214,000 on my motor, and it run like a champ. Now the trans (A4) did not make a 110,000 miles.
11-02-2010, 05:21 AM #12
- Apr 2006
- Charlotte, NC
Hugger Orange/W stripes- 1999 Z28 M6
My '99 M6 is a daily driver and is near 110,000. No engine issues at all except for the A.I.R. which is about to go bye-bye and be tuned out.
Still has the original clutch. It's weak but still doesn't slip when fully released at low rpm's and labored. Rear-end will likely be the first thing to go. Pinion seal leaks.
I use Pennzoil Platinum 10W30 and change it around 5000-5500 miles. If I go to the later mark it usually is hovering around a quart of oil being used to keep it full.
I'm not abusive to it, but I will rev it out from time to time.
11-02-2010, 06:44 AM #13
- Dec 2006
- Jenks/Tulsa
Light Pewter Metallic- y2k 8-cylinder catfish
48k on the motor and drive-train and still running great! Welcome to the forum!
11-02-2010, 06:56 AM #14
- Dec 2006
- Winter Garden, FL
Black- 1999 Camaro Z28
113k. 1 rear, original clutch. No other issues.
11-02-2010, 07:39 AM #15
- Jan 2006
- Shepherd, Michigan
107k. Cat went bad and maf went bad, and tps ..no biggys tho..i will stretch my car's legs quite a bit
11-02-2010, 12:18 PM #16
- Nov 2009
- Norfolk, Nebraska
- 2002 Camaro Z28
Just under 113k here. Trans shifts very well with no signs of wear. Engine sounds scary at cold startups for the first minute or two. Damn piston slap. Planning an LS6 swap. Other than that car runs and drives great. I'll drive it til it breaks then fix and repeat.
Junkyard bought and "refurbished" 2002 Camaro Z28 - Pacetter Race LT's, TS&P ORY, Frost tune, Magnaflow, Ported TB, SLP Lid, Circle D 3000, 3.73's, SFC's.
2009 Silverado Z71 - Magnaflow
2008 Impala LTZ - Wife didn't want the V8 SS!
11-02-2010, 12:57 PM #17
Just turned 20K...inside still smells new
Broke the synchro keys at 12,000 miles so I upgraded the entire T56 at that point.
Mods in signature.Boost gets you laid, unless your name is Jon.
11-02-2010, 12:58 PM #18
11-02-2010, 01:04 PM #19
130k. solid car all the way around. decent mileage for a 5.7. reliable with routine maintainence.
11-02-2010, 01:26 PM #20
Nearly 108k on mine, I bought it with 63000 miles. They haven't been easy miles either
how long will it last
By timothyodell2525 in forum DrivetrainReplies: 8Last Post: 09-19-2011, 12:52 PM -
BBK Long-Tube Headers Install - Going Long
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 09-09-2011, 06:30 PM -
dad had a saying..... (long)
By 0rion in forum Almost Anything GoesReplies: 40Last Post: 03-26-2010, 10:43 AM -
How long?
By scheier in forum Request and FeedbackReplies: 18Last Post: 01-05-2006, 03:22 PM
