Results 1 to 1 of 1
Thread: 93 GMC 4.8LS swap
09-05-2022, 06:06 AM #1
- Sep 2022
- MO
93 GMC 4.8LS swap
I have a 4.8LS from a 99 Silverado that I want to swap into my 93 GMC Sierra. GMC has a Getrag MG5. The 99 had an NV3500. The 4.8 came with flywheel, clutch disc and pressure plate. Input shaft is 10 tooth for both. Pilot bearing looks to be the same. I will replace disc and pressure plate and reface the flywheel. I know that the two trannies are very similar, but am I on the right track? BTW, I am keeping the 4.8 stock so there should not be an issue with too much juice for the tranny. Also, anyone have any ideas on turnkey kits? Don't have the ecm from the 99, and I want to keep the 93 electronics and gauges stock. The cab is very clean and it all works. Thanks!
Question: LS swap automatic to manual swap
By Slone289 in forum LSx Retrofit and SwapReplies: 0Last Post: 04-14-2020, 09:48 PM -
Trans swap for swap
By [CJ] in forum DrivetrainReplies: 0Last Post: 08-12-2011, 12:11 PM -
Engine swap and computer swap
By mrmiatanut in forum Computer & TuningReplies: 4Last Post: 09-08-2007, 05:10 PM -
Got a 94 Stang, want to swap a ls1 into it. Anyone hear of a swap kit?
By oxemoron in forum General HelpReplies: 6Last Post: 01-30-2006, 01:02 PM
