08-04-2006, 07:56 PM #1
- Nov 2005
FAILURE OF OPTISPARK!? What are the symptoms?
I've heard alot about the optispark failing in the LT1's but I have failed to find somewhere on this site what the symptoms are. My car symptoms are as follows,
1. My car runs like crap when I try to take off it feels powerless.
Once I get over say 4000 RPM or a certain speed my car doesn't feel powerless But........
My Z has a A4
The redline starts at 5,000 RPM on an LT1, it's dotted until it gets to 6,000 Then turns solid between 6,000 and 7,000 RPM
WELL it doesn't take a rocket scientist to figure out that red is bad "Dotted Red is BAD" "Solid RED is REALLY BAD"
2. MY Car shifts at 6,500 RPM!!! when I floor it, Thats 500 RPM before the max readout. "This is not normal RIGHT?
3. When I am at a stop light the idle drops to about 500 RPM and my car starts to sway from side to side it feels like it has a 500 in it!
Are these the symptoms of optispark faliure or what is the problem.
Could it be a specific sensor?
Maybe two different problems?
08-05-2006, 02:30 AM #2
wow, that could be alot of things.... One thing I can tell you... 6500 rpm is hazardous to the health of your LT1 motor, and the valvetrain may not take that abuse many times. Try to avoid that if possible. One of the main symptoms to look for is a hesitation, ie the car wont pull smoothly through the power band, as it is randomly missfiring.
08-05-2006, 04:55 AM #3
- Sep 2005
Yea like he said it could be anything.
Does it have any lights that come on? If no then just start checking random stuff. Check the fuel pressure and drive around with it taped to the windsheild if you have to.
Then if that checks out fine it's not a fuel related problem. After that just check the opti and other sensors.
08-06-2006, 05:13 AM #4
- Jul 2006
- NC
Yeah 6500 def isnt good on a stock valvetrain. Also check you plug wires at night and make sure you arent arcing out. What mods you have done??
08-07-2006, 09:37 PM #5
- Nov 2005
No Mods just stock. I can't figure out what's wrong. Could it be optispark?
I don't get a "check engine" light thats what worries me, if it was misfiring I would get a "check engine" light. Is it possibly any type of sensor
Also what is that whooshing sound I get after it shifts? I thought it was the belt slipping but it's not.
P0740 (no symptoms help)
By Letzride in forum Automatic TransmissionReplies: 5Last Post: 05-22-2014, 05:26 PM -
Help: Cam symptoms
By Lunatikgixxer in forum Internal EngineReplies: 17Last Post: 10-27-2010, 07:10 PM -
Help: Symptoms of bad maf sensor?
By LS1junkie18 in forum General HelpReplies: 14Last Post: 02-22-2010, 04:10 PM -
What are the Symptoms of a bad cam lobe
By Justin93 in forum Internal EngineReplies: 6Last Post: 04-16-2009, 12:08 AM -
Symptoms...
By Mr. Luos in forum Internal EngineReplies: 10Last Post: 02-04-2006, 07:26 AM
