Thread: Car jumps when shifting from R-D
07-06-2007, 02:40 PM #1
My 2000 Trans Am has had this problem for a while now, the problem is when i shift from D-R, or from R-D, the car jumps, and makes a thumping sound, it also does it while braking, and when i go over speed bumps and such, i initially thought is was caused by a warped rotor so i replaced all four with drilled and slotted, then i figured it was the shocks going out so i replaced all four, with bilsteins, and new eibach springs, but my car still does the same thing, i need help because its getting more and more frustrating!!!! Thanks!!
07-07-2007, 07:09 PM #2
Sounds like a:
possible motor mount or tranny mount.
Can't think of anything else that could cause it except for high idle, but then there wouldn't be a thump.
07-08-2007, 07:35 PM #3
check your trans mount.
07-09-2007, 08:03 PM #4
...Another Rat Jumps Overboard...
By wileyCoyote in forum Political / Debate ForumReplies: 8Last Post: 01-09-2012, 09:53 PM -
power shifting rear end jumps
By turyg ls1 in forum Camaro / SSReplies: 13Last Post: 05-10-2011, 10:46 AM -
Car jumps tollbooth
By doberman 152 in forum Almost Anything GoesReplies: 13Last Post: 06-08-2010, 08:36 AM -
Car jumps when Shifting from R - D???
By lx24 in forum Automatic TransmissionReplies: 24Last Post: 08-02-2007, 06:57 PM -
Jumps out of third
By BIG D's SS in forum Manual TransmissionReplies: 10Last Post: 09-23-2005, 11:18 PM
