Results 1 to 2 of 2
Thread: Leak from Rear of car
03-04-2007, 12:47 PM #1
- Jan 2006
- Memphis,TN
Black- 2001 Z28 Camaro
when i was replacing the a/c belt a few days ago from under my car i noticed i had a small wet spot near the rear of my car and this is what i found:
Havent got it looked at yet b/c im not sure whats wrong or how to explain it. the leak is very small and takes a day or two for any fluid to hit the ground.
Anyone have any ideas what needs to be fixed and how much?
03-04-2007, 01:05 PM #2
Looks like a little weepage from the rear. It looks like a floor jack has bent the cover a little bit and that may be how it started. A new cover gasket and some loctite on the bolts usually do the trick. You may also want to check that the vent isn't blocked, which could also cause the fluid to be pushed out.
Rear End leak ?
By justhend in forum DrivetrainReplies: 12Last Post: 07-08-2013, 05:43 PM -
Rear end leak?
By ESBdieselcam in forum General HelpReplies: 13Last Post: 04-07-2010, 06:55 PM -
Help: Rear end leak
By Rhinohuey in forum DrivetrainReplies: 21Last Post: 03-26-2009, 04:27 AM -
Rear end leak
By ezwip in forum DrivetrainReplies: 10Last Post: 09-04-2008, 10:11 PM -
Rear End Leak?
By SexyWS6Mama in forum DrivetrainReplies: 32Last Post: 12-29-2005, 06:54 PM
