    - = LR = - grandkodiak's Avatar
    x
    Broken clutch fork... symptoms?
    What is the clutch fork and what would the symptoms be if it were bad or not installed properly?
    Member jimmy77611's Avatar
    Feb 2007
    Here
    2000 Z28
    Your pedal would most likely feel like it has no resistance when you push it, and may even stay down. The clutch would never disengage, so if you tried to start the car in gear it would try to lunge, or if you started it in neutral, you wouldn't be able to get it in gear. These could also be symptoms of a bad slave or master cylinder.
    x
    hmm ok not that then... thanks
    Feb 2007
    Here
    2000 Z28
    What's it doing?
    doylestown, Pa
    SILVER
    2004 CTS-V
    If you had it apart and it went back together, then it certainly isn't installed incorrectly. It sure is a PITA!
  1. Wanted: stock alum. 3-4 fork
    By hec33 in forum Parts Wanted / Trade
    Last Post: 08-09-2010, 01:09 PM
  2. What is shift fork overextension?
    By freddy_caprice in forum Manual Transmission
    Last Post: 09-24-2009, 10:46 AM
  3. Broken clutch fork
    By Y2K_WS6 in forum LT1
    Last Post: 06-07-2009, 12:00 PM
  4. Broken clutch fork
    By Y2K_WS6 in forum Manual Transmission
    Last Post: 05-26-2009, 09:29 PM
  5. How much for shift fork fix?
    By 96 blue maro in forum Manual Transmission
    Last Post: 03-02-2007, 06:16 AM
