07-27-2008, 04:43 PM #1
Changing trans fluid and rear end fluid
Im changing all the fluids on my car which is a 98 z28 A4 with 143k miles. What trans fluid do you guys recommend ? i was thinking about going with pennzoils trans fluid which states its better then dexron III. And for the rear end what oil should i go with ? also which weight ? any advice is appreicated thanks!
07-27-2008, 05:19 PM #2
I use what ever name brand is handy lately it has been texaco havoline tranny fluid. Also the tranny filter seal was a real bearcat to get out in mine. After messing with it for an hour, I finally drove a small screw driver behind it, crushed it and pulled it out with a pair of needle noise pliers. I used a socket to drive the new seal in.
07-27-2008, 05:49 PM #3
For the transmission, go with synthetic Dexron III such as Mobil 1, Amsoil, or Redline, or you can go with the new GM fluid, which is Dexron VI. The #1 killer of auto trannies is heat, so the last thing you want is the fluid breaking down when your running it hard and the trans starts to heat up.
For the rear you'll need 75W-90 weight gear oil. For best protection and performance go with a synthetic such as Mobil 1. You'll also need a tube of limited slip additive from GM or the auto parts store.
07-28-2008, 05:14 AM #4
AMSOIL Synthetic Lubricants
Hi 98Z28importslyer,
Below is the recommendation from Amsoil for your application.
Automatic Transmission, Total Fill
4 speed 4L60E..........11.0 quarts
Amsoil ATF link
AMSOIL ATF is recommended for GM Dexron II, III, and VI.
Standard Differential, Rear .....GL-5
All Temps......75W-90
Controlled Slip Differential, Rear .....GL-5
Differential, Rear..........3.6 pints
Amsoil 75W-90 link
Note: AMSOIL SEVERE GEARĀ® is compatible with most limited slip differentials. If limited slip differential chatter occurs, add AMSOIL Slip-Lock friction modifier additive.
Amsoil Slip-Lock link
Let me know if you have further questions,
CompSynLast edited by CompSyn; 07-28-2008 at 06:27 PM.
07-28-2008, 03:13 PM #5
07-28-2008, 05:37 PM #6
For the rear end just use any 80/90 dino gear oil.
07-29-2008, 08:33 AM #7
changing trans fluid???
By twozs in forum Automatic TransmissionReplies: 18Last Post: 08-19-2010, 10:22 AM -
Changing diff fluid..
By ls1fan74 in forum GTOReplies: 37Last Post: 09-03-2009, 09:10 AM -
Clutch fluid changing
By ls1fan74 in forum GTOReplies: 1Last Post: 04-24-2009, 05:44 PM -
Changing own Trans Fluid?
By Patsy57 in forum Manual TransmissionReplies: 7Last Post: 04-11-2008, 02:58 PM -
Changing tranny fluid.
By yellowv in forum Manual TransmissionReplies: 3Last Post: 02-17-2007, 09:11 AM
