Results 1 to 2 of 2
Thread: Misfire! Misfire!
07-15-2007, 06:47 PM #1
- Jun 2007
- Albany, NY
black- 2002 Camaro B4C SS
Misfire! Misfire!
I know there are some other threads on this subject, but I want to know if anyone is having a similar problem. I keep getting a cylinder 7 misfire code P0307. The coil, plug and plug wire are brand new. It takes a fair amount of driving to get it to happen, but it does happen about every third time driving. It must be real suttle because I don't feel it happen. Has anyone had a misfire issue with cylinder 7? I know there was some talk about bent valves and bad injectors, but could it be the cat converter on the drivers side since it is directly downwind from #7?
07-15-2007, 08:18 PM #2
Take that plug out and see if you cracked it while you were putting it in. I had that problem
Question: Misfire???
By motorhead584 in forum General HelpReplies: 8Last Post: 04-06-2014, 02:56 AM -
Help: could a bad o2 cause a misfire?
By SteveCZ28 in forum General HelpReplies: 18Last Post: 07-25-2011, 04:10 PM -
Misfire cyl #3 HELP!!!!
By blownh2x in forum General HelpReplies: 16Last Post: 03-28-2009, 11:06 AM -
Misfire on #1
By INeedLS1 in forum General HelpReplies: 4Last Post: 04-22-2007, 06:44 PM -
3.8 misfire
By andrew rs in forum V6Replies: 4Last Post: 03-10-2007, 08:33 AM
