Thread: Misfire on #1
04-21-2007, 08:12 AM #1
Misfire on #1
I have a misfire on #1. It seems to only happen during the first few minutes after I start the car either hot or cold. How can I tell if it is a plug, wire or coil problems?
04-21-2007, 08:47 AM #2
- Oct 2006
- Oklahoma City
00 LS1, WS6, V8 Gremlin- 96 & 98 GTPs, 64 'Cuda
Try swapping the coil with a different one to see if the problem moves.
Remove the plug and inspect it for hairline cracks in the ceramic insulator.
You can ohm out the wire but that's not always accurate.
If the problem persists chances are you've got a gummed up or otherwise failing injector.
It's a good idea to try a profesional injector cleaning before replacing an injector. We sell a kit that close to the price of a single new injector which can not only be used to clean all of yours but it can be re-used over and over again on as many different cars as you like.
04-22-2007, 07:00 AM #3
- Dec 2006
- Standish,Maine
Artic White- 00 SS Vert.
JIGGER RACIN'
2000 Camaro SS, vert., auto., LS6 intake manifold, SLP lid, K&N filter, SLP LoudMouth II, C5 Z06 replica 17x9.5 rims
1/4 mile time = 13.310 sec. @ 105.22 mph, 2.051 60'
http://www.cardomain.com/ride/2939958
http://i158.photobucket.com/albums/t...amarolaeft.jpg
04-22-2007, 06:30 PM #4
- Feb 2007
- Pa
Red- 99 TA
might be valve seals.very common cause of misfires on starts that gets overlooked.if the intake valve oil seal leaks a little when the engine is off the 1st thing the plug gets is a squirt of oil that will cause it to misfire until it burns off.sometimes the guide is worn too.if the guide is worn it will wear the new seal too.to check this do this test,start the engine and as soon as it starts to miss turn it off.pull the plug and check to see if its oil fouled.if it is its the valve seal.if its gas fouled it could be the injector,pcm,wiring or plug.i'm betting its oil fouled.
04-22-2007, 06:44 PM #5
Pull the plug and see what's going on...is it fouled? Check for spark...pull the wire off the plug, put a screwdriver across the end and ground the screwdriver. Crank it but don't start it...check for an arch. If you get spark and the plug is ok you can swap and pop the injector...could also be a valve seal like Rivi said
Question: Misfire???
By motorhead584 in forum General HelpReplies: 8Last Post: 04-06-2014, 02:56 AM -
Help: could a bad o2 cause a misfire?
By SteveCZ28 in forum General HelpReplies: 18Last Post: 07-25-2011, 04:10 PM -
Misfire cyl #3 HELP!!!!
By blownh2x in forum General HelpReplies: 16Last Post: 03-28-2009, 11:06 AM -
Misfire! Misfire!
By surgitech74 in forum Camaro / SSReplies: 1Last Post: 07-15-2007, 08:18 PM -
3.8 misfire
By andrew rs in forum V6Replies: 4Last Post: 03-10-2007, 08:33 AM
