Results 1 to 20 of 36
Thread: 100k
09-24-2010, 08:19 AM #1
100k
just hit a 100k miles in the 02 z28 and was wondering is it still ok if i change the heads and cam and spray it? or should i just not do anything to it and save for another block and build that one?
09-24-2010, 08:47 AM #2
- Aug 2010
- Oklahoma City, Oklahoma
sebring silver- Y2K SS CAMARO
you wouldnt need to buy another block just rebuild the one that you have but personally i wouldnt do it because knowing my luck i would throw a rod and have to replace everything just my .02
09-24-2010, 08:47 AM #3
09-24-2010, 08:49 AM #4
so what do you think? just heads and cam?
09-24-2010, 08:53 AM #5
Seems like we have lots of guys on here upgrading and running their cars hard with more miles than that. If it breaks, you just fix or replace it. It also appears that replacement LS short blocks are not all that expensive.
09-24-2010, 08:55 AM #6
man this is also the daily driver keep that in mind folks....
09-24-2010, 08:55 AM #7
should i just do heads and a cam and full bolt ons?
09-24-2010, 08:56 AM #8
09-24-2010, 08:56 AM #9
09-24-2010, 08:59 AM #10
09-24-2010, 09:03 AM #11
09-24-2010, 09:09 AM #12
09-24-2010, 09:11 AM #13
damn that just set my plans back for a few more months
09-24-2010, 09:11 AM #14
09-24-2010, 09:12 AM #15
well i do still need to buy a clutch and since im not going to mod it like how i wanted to should i just buy a replacement one and go buy the monster clutch later on after the build?
09-24-2010, 09:17 AM #16
We have around 75,000 on our car. The plan is to upgrade the transmission and torque converter over the winter and then go racing next year with it. Heads and cam will then be the next mod if I decide to step it up another notch -- we'll have to see how the car runs.
09-24-2010, 09:18 AM #17
Well you live in Cali so I can see the dilema with your car being a daily, (no winters).. Out here in the north east, winter is mod/build time.. I may do some minor things here and there.. Mostly because my current project is taking so long.. So I'm gonna get all the driving I can this season out of the Camaro, there wont be another for a while for her after this one..
09-24-2010, 09:36 AM #18
- Aug 2010
i would go ahead and buy the gorilla clutch now cause theres no since in buying one only to replace it again unless its going to be a while before you do the motor
09-24-2010, 10:24 AM #19
Well I was thinking I should just get a forged block and that can take close to a yr
09-24-2010, 10:34 AM #20
- Mar 2007
- Henryetta/Tulsa Oklahoma
If you are going to daily it, don't upgrade it in my opinion. I have very few mods to mine. Have daily'd it pretty much from 88k to now, 193k. I have replaced every accessory at least once, aside from power steering pump. I've got a lot more tic sounds than I used to, and that's with pretty much a header only car with 90% highway miles. I could only imagine what running spray would do to a DD car...and even heads and cam is most likely shortening the life of the bottom end. If you do go ahead and do heads and cam, I would get some ARP rod bolts to go with. You'll probably need an oil pump as well to go with head/cam setup, so the oil pan will be off anyway
I would just make her sound good and look mean if you are going to DD her.... or like said above, get a beater for the daily stuff and do as you please with the F-body.
Synthetic oil after 100k
By johnfin in forum Internal EngineReplies: 4Last Post: 08-18-2016, 06:34 AM -
100K PMs
By grouch0jr in forum General HelpReplies: 3Last Post: 03-24-2011, 12:55 AM -
just hit 100k last month
By JayTA98 in forum General HelpReplies: 2Last Post: 11-01-2010, 05:33 AM -
100k+ help
By FullBlack4thGen in forum Forced InductionReplies: 2Last Post: 07-11-2009, 04:18 AM -
100k...almost
By third_shift|studios in forum Firebird / WS6Replies: 12Last Post: 10-29-2005, 11:36 AM
