Thread: Headlight Motor
03-23-2010, 05:29 PM #1
- Feb 2010
- Abilene Tx
- iTrader
- 0
White- 1998 FireBird Formula
Headlight Motor
Just like the tittle says, i need a good working headlight motor to go on my 98 formula. Price shipped to 79605.
Thanks
03-24-2010, 05:06 AM #2
- cleveland ohio
- iTrader
- 48 (100%)
trans am 00 ws6- 1998 camaro ss vert
is it grinding when you set the alarm? if so you just need the gear. if that is the case pm me. i'll send you a link.
03-24-2010, 08:35 AM #3
- Feb 2010
- Abilene Tx
- iTrader
- 0
it was just grinding when it went down, i took the lift arm off and turned it 180* to use the other half of the gear, then it was grinding while going up and the light would bounce. I tried to put it back to how it was before and now the gear is just shot. I've seen the kit to replace the gear, i just thought i would change the whole motor if i could get one for a good price.
now i need to change it asap and i found that autozone sells replacement gears for $15 so i'm going to just go with that for now.
03-24-2010, 08:54 AM #4
03-24-2010, 01:39 PM #5
- Feb 2010
- Abilene Tx
- iTrader
- 0
i'm pretty sure the one i ordered is plastic. But it will be here tomorrow morning through napa, like i said i needed one ASAP since my headlight wouldn't go up at all. I will be getting the brass ones eventually but this one was only $12 so not to bad..
i pulled the headlight assem. out of the car and took the motor apart to see how the gear looked, wow... i think it had already been turned before because the entire gear was wore down, even missing a couple teeth...
04-29-2010, 07:17 AM #6
- Jan 2010
- Phoenix, AZ
- iTrader
- 0
Red- 2000 Trans AM
did u sell the passenger side?
headlight motor
By edrvsqz1980 in forum Firebird / WS6Replies: 6Last Post: 07-15-2011, 06:17 AM -
Question: Headlight motor
By 00hawk109 in forum General HelpReplies: 5Last Post: 06-14-2011, 06:27 AM -
Wanted: 97 ws6 headlight motor
By Blue Sun in forum Parts Wanted / TradeReplies: 0Last Post: 07-19-2009, 06:17 AM -
Headlight Motor
By Wesman in forum General HelpReplies: 4Last Post: 05-08-2008, 08:11 PM -
WTB: Headlight motor and...
By DW2000TA in forum Parts Wanted / TradeReplies: 0Last Post: 01-08-2007, 09:41 AM
