Thread: Timing
05-19-2012, 03:47 PM #1
Timing
Hey guys its been awhile since i have posted on here. i have a quick question. i was cruising on the freeway with my predator plugged in and i noticed my timing seems a bit high? cruising in 5th gear at 2300 rpms my timing was +40. is that high? at idle it bounces between 18-23 degrees according to the predator. i did a WOT run in 5th gear and timing retarded to +20 degrees. my engine is stock except a K&N, ported TB, ported/de-screened MAF, 160 degree thermostat and dynotune. and the plugs are TR6's. im curious if it could be my MAF? thanks!
05-19-2012, 08:33 PM #2
no.....that's normal. Depending on where you were on the spark table (g/cyl vs rpm) it should probably be in the 38-40 range. WOT, again depending on where you're at on the table, should be in the 19-23 range.
05-20-2012, 06:27 PM #3
- Apr 2009
- Pennsylvania
Pewter- 2000 Camaro SS
05-21-2012, 03:16 AM #4
here's what the table looks like for an 01. Granted...this is an a4 car but it'll give you an idea of what your spark should look like. Notice in the 2400 rpm range ( columns) at lower g/cyl (rows) how the spark is in the 40 range roughly. Also....WOT will be anything above about .60 g/cyl and 3600rpm.
Help: 98 T/A Timing!!
By 90ARAPAJ in forum Firebird / WS6Replies: 4Last Post: 06-30-2011, 09:16 AM -
Question: Ign. Timing?
By crazychevydave350 in forum Computer & TuningReplies: 1Last Post: 06-19-2008, 10:36 AM -
Ls1 timing cover, Dual row timing chain
By xssive in forum Parts For Sale / TradeReplies: 0Last Post: 08-06-2007, 06:41 PM -
timing???
By Ridinfilthy in forum Computer & TuningReplies: 2Last Post: 04-08-2007, 07:27 PM -
neg.timing?
By bowtieguy45 in forum LT1Replies: 6Last Post: 09-28-2006, 08:56 PM
