Results 1 to 10 of 10
Thread: single or three bolt cam?
08-22-2010, 10:25 PM #1
- Aug 2010
- Clarksville, Ar
various- 1986 Turbo 944
Purchasing a short block without a cam.
I am not sure what cam I am suppose to use, single or three bolt.
it is an ls1 with forged pistons, h beam rods, stock crank and I am running ls6 heads with dual springs.
any help would be nice.
thank you
08-23-2010, 05:41 AM #2
- Thornton, CO
What are you referring too?
What bolts? On the end of the cam there should be three bolts. They hold the cam timing gear on.
08-23-2010, 07:16 AM #3
- Aug 2010
- Clarksville, Ar
ok, comp cam ask if my cam was a single bolt or three bolt. It refers to the ones at the end of the cam. They have one that has just a center bolt and a offset tab that inserts into the gear. But I will stick with the three bolt then.
08-23-2010, 09:09 AM #4
- Thornton, CO
They do have an offset tab. Even the 3 bolt.
I haven't been inside the Gen IV LSx...maybe they are a bit different.
Used in my 1999 LS1 and my 2004/05 LQ9
08-23-2010, 09:46 AM #5
- Aug 2010
- Clarksville, Ar
thanks
08-25-2010, 09:25 PM #6
08-26-2010, 05:07 AM #7
- Oct 2007
- NC
SOM- 1998 T.A.
12-25-2020, 03:35 AM #8
- Dec 2020
- Niangua Missouri
I know this a old thread but you can run a single bolt in a gen 3 . It’s not better than a three bolt but you can do it??? Am I wrong or am I on the right track. Reason I ask is I just bought a factory ls3 cam to put in a gen3 5.3 . I heard it is a notable different cam with the gen 3. 5.3 having the smallest cams of the ls family and the 6.2 having the largest it’s a cheap upgrade. So can I use it in my 5.3 even though it’s single bolt and vvt?
12-28-2020, 10:37 PM #9
- Dec 2020
- Nor cal
Yes you can, just have to get a one bolt trimming gear
11-24-2022, 09:47 PM #10
- Nov 2022
- amesterdam
Showbox jiofi.local.html tplinkloginLast edited by mikelstudy; 11-25-2022 at 02:58 AM.
Bolt-In Rearend Buyers Guide - Bolt-In Rearends -
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 08-25-2010, 02:40 AM -
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 08-24-2010, 02:40 PM -
Sound clip needed for single-in single out exhaust.
By KIXASS in forum External EngineReplies: 0Last Post: 09-13-2007, 06:27 PM -
Center bolt to Perimeter bolt Heads, Coil Mounting help
By juiced99ws6 in forum Internal EngineReplies: 7Last Post: 03-30-2007, 11:38 PM
