Results 1 to 20 of 30
    NW Indiana
    00 NHRA Trans Am
    Headers/cats emissions question
    Bear with me as this might be long.... My car has been rejected by the Indiana emission test for the last 3 tries with this "Incomplete monitor: catalyst" then all of a sudden right after the last test earlier today my Check Engine light came on. Of course it's the P0420 code for converter efficiency below threshold. As I see converters aren't cheap for my car, I was thinking of finally getting around to headers/y-pipe with no converters. Now, if I go with this setup with o2 sims this will pass the emission test, right? It won't show "Incomplete" again? Just wanna make sure I'm on the right path here
    Also I just put a Dynomax racebullet catback on my car for the stock exhaust, will this work with the y-pipe that comes with the headers? Thanks for any help with this.
    2000 NHRA Edition T/A Pewter
    A4 3.23 Midwest 3200, Lid, MAF Ends, Ram Air Kit
    NX wet Kit - Best 60ft:1.67
    1/8th:7.48@94.34n20
    1/4:11.67@116.58n20
    I'm not sure where you are located, but some states require you keep them and LT headers aren't legal like here in CA.
    NW Indiana
    00 NHRA Trans Am
    I'm in Indiana and as far as legal, I'm not sure either but I do know they don't do the "use a mirror to see a cat/s" thing like they do for older cars, only the gas cap check and computer.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    I'm from Indiana and they do not do a visual inspection. Just OBDII plug in. I do not have catalytic converters and I have LT's installed and pass without issue.
    You may just have a bad O2 sender. Any drop in mileage or driveability issues?
    NW Indiana
    00 NHRA Trans Am
    Nothing noticeable, I do have autotap as well as a predator programmer that'll give me voltages on them, what should I look for as far as knowing if I have a bad one?
    NW Indiana
    00 NHRA Trans Am
    I just checked voltages with my predator and here's what I got:
    Idle 2000rpm
    Short Term Bank 1 .78-1.56 0-4.69
    Long Term Bank 1 3.91 14.06
    Short Term Bank 2 .78-1.56 0-4.69
    Long Term Bank 2 3.91 17.97
    What do you think?
    Sorry, can't get the columns to line up.
    You would have to look at Bank 1, Sensor 2, which is the rear O2 sender (after the cat, or on the cat -- I cannot recall) on the driver side. The front sensors are what help control fueling. The rear sensors simply tell the PCM if the cats are functioning correctly. You could also swap the rear O2 senders from side to side and see if the problem moves with the sensor, or if it stays on the driver side.
    NW Indiana
    00 NHRA Trans Am
    Sorry for the late reply... was out of town. I'm going to try swapping them and see what happens. Thanks for the help with it.
    Marylandistan
    2001 Trans Am (sold)
    02 simms will work. I used them back like 12 years ago. I had one of em go bad tho and had to get another. If you can find a tuner it's worth it to have him tune out all the emissions codes.
    NW Indiana
    00 NHRA Trans Am
    Will sims tell the computer they are "ready" That's the problem I'm having. Or if they were tuned out, will it show "ready"
    NW Indiana
    00 NHRA Trans Am
    Do your 02 sensors status show "ready" or "complete"? My autotap still shows the catalyst as incomplete.
    Marylandistan
    Quote Originally Posted by Dano 00TA View Post
    Yes.
    I'm assuming yes as I have never had any issues with passing emissions. My rear O2 sensors have been tuned out for a long time now.
    NW Indiana
    00 NHRA Trans Am
    Well, I ordered a set of TSP 1 7/8 headers/ory and of course after they shipped I remembered about the A.I.R hookup which as my luck runs, have none. Might have to have these removed also now or see if I can find bungs to have them welded on.
    Ditch the secondary air -- it's easy: http://www.ls1.com/forums/f6/seconda...emoval-130641/
    You'll want a tune anyway with the new headers, so have the secondary air code shut off so you do not end up with the SES lit up.
    NW Indiana
    00 NHRA Trans Am
    Thanks for the help with this! I'm gonna probably invest in HP Tuners now so I can get this all done.
    Member RONS98TA's Avatar
    MARYLAND
    BLACK
    1998 PONTIAC TA
    HP tuners is something you really don't wanna mess with unless you know what you know what your doing. I would just get a mail order frost tune. It's cheaper anyway.
    Member speedyWS6's Avatar
    Sep 2009
    U.K.
    2002 WS6 TA
    Quote Originally Posted by RONS98TA View Post
    Yep!
    Pretty foolproof. I have had zero issues with my Frost tune and
    coincidentally i too have the TSP LT's.
    Bit of a story there about fitment... but all good if you get the correct
    headers!!!
    NW Indiana
    00 NHRA Trans Am
    Yeah, might just go with a frost tune then, was just thinking of more mods later and the ability to tune again w/o having to need another mail tune. Thanks
    I have been reading some horror stories with these headers and read some went pretty easy, hopefully mines the later.
  1. Cats for emissions
    By BirdCountry02 in forum External Engine
    Last Post: 12-20-2010, 07:11 PM
  2. Question: NW ATL GA Area Emissions & LT Headers
    By Mark_O in forum Southern Members
    Last Post: 12-20-2009, 03:18 PM
  3. Headers and Emissions
    By See Me In My GTP in forum External Engine
    Last Post: 03-25-2009, 04:08 PM
  4. Wanted: LT Headers & Y w/ emissions
    By michaelinchains in forum Parts Wanted / Trade
    Last Post: 02-02-2009, 05:10 PM
  5. Emissions legal headers PA?
    By 02ultraZ in forum External Engine
    Last Post: 06-21-2007, 03:47 AM
