Results 1 to 20 of 26
Thread: 1970-1972 ho
04-10-2006, 07:36 PM #1
- Sep 2005
- chicago
yellow- 2002 collectors edition
1970-1972 ho
I think the baddest trans am ever made were the 1970-1972 trans am, does anybody esle out thier own one of this bad boys.
05-02-2006, 09:43 PM #2
- Mar 2006
- California
Blue on White & Dark Blue- 70 TA RA III & 02 TA WS6
I do... transamrit.net/transam/ (damn forum won't let me create a real URL yet).
'70 TA Ram Air III. It's awesome, soon to be awesomer (hopefully).
05-02-2006, 10:14 PM #3
- Sep 2005
- chicago
CHECK OUT MY PROJECT CAR www.dmperformance.org , click on project car page.
05-02-2006, 10:41 PM #4
- Mar 2006
- California
Very nice. I'm planning on doing something similar, soon. About 800-900hp, good mileage via T56 6-speed, etc. Only difference is, I'll be using the Pontiac 400 block instead.
05-17-2006, 12:23 PM #5
dont have one right now . Got rid of a 74 Formula with a 455 a while back
05-19-2006, 08:44 AM #6
- May 2006
- Oklahoma
red- 1973 TransAm
I have a 1973 TA with the 455, I have been a car guy that believed you should keep the same engine make as the car, I think I'm finally have gotten over that, because I'm now looking for a LSx engine and trans to put in the 73TA with a turbo.
I just now starting to look at info on the LSx engines, I want to find a wreck car so I can have everything engine and acc. do you have any starting points on what I should look for. Car/year ?
05-19-2006, 09:16 AM #7
- Mar 2006
- California
Originally Posted by DeWayne
05-19-2006, 10:35 AM #8
- May 2006
- Oklahoma
red- 1973 TransAm
Originally Posted by TransAMrit
05-19-2006, 08:42 PM #9
- Mar 2006
- California
I gotcha. I'm kinda surprised that the LS1 is cheaper, especially considering that you already have the 455 - I assume you don't have a spare LS1 sitting around.
Maybe if I get my turbo 400 done before long, I can convince you to go the same route...
05-24-2006, 12:06 PM #10
- May 2006
- Oklahoma
red- 1973 TransAm
I have had a friend offer to trade a complete LS1 for the 455, I'm torn about what to use, what does everyone else think ? Trade or not ?
06-07-2006, 05:08 PM #11
- Jan 2006
- Saginaw
- 69 Firebird, 02 Firehawk
dont trade!!
06-07-2006, 06:39 PM #12
- Sep 2005
- chicago
I know, I might just put it back to stock, I aslo have a 69 tubed camaro that can get the turbo, ls1, but that car is far from bieng done,, my trans am is so awsome, and its almost done, I did just pick up a complete 71 455 , with 6x heads on it, I could get 600 ft pound, out of it if I pick the right cam. I cant decide.
06-08-2006, 07:16 AM #13
- Jan 2006
- Saginaw
Im about done with my 455, comp cams make several nice cams for them, I went with a .488 lift, with the 1.65 rocker, that brings it to about .530 or so. May not sound like much to an LS1, but thats a good for a pontiac motor. I also put RAIII heads, for about 11.5:1 compression. I still need the carb and a balancer, then Ill be done.
06-08-2006, 11:10 AM #14
- Sep 2005
- chicago
that a real nice cam, what is the duration?
06-14-2006, 09:41 AM #15
- May 2006
- Oklahoma
red- 1973 TransAm
Originally Posted by 1Last69
Here is a link on a 455 build.
carcraft.com/techarticles/116_0306_pont/index4.html
The RAIII heads is what I used on my 455. Number 3 cylinder wall collapsed with a hole about the size of a quarter, I had it re-sleeved. Then I started doing some research on the 455 had some bad casting on that cylinder with some of the 455, The article said to have your block sonic test, make sure you have plenty of wall thickness for that compression, If I can find that article, I will post the link.
06-14-2006, 05:10 PM #16
- Jan 2006
- st. clair
blue- 2002 ws6 trans am
[ATTACH] [/ATTACH]
06-15-2006, 05:35 PM #17
My friends '72
08-27-2006, 11:33 PM #18
I know this is old but,a pontiac 455 can make as much if not more power than a LSX engine, stick with the 455, stroke it, cam it and put some KRE heads on it with a nice set Harland Sharp RRs and you'll easily, run with ls1s with a fair amount of mods, remember ponchos don't need alot of cam, more precisely duration, 2.11in./1.77ex. valves are large, plus a big cam with alot of lift will eventually break your #6 lifter bore, ponchos don't need to rev to make big power, check this out www.pontiacengines.com scroll down and read
2006 impulse blue G.T.O
Iron Block 408
Cam
Pacesetter ceramic coated L.T.s
LMII exhaust
K&N CAI
Ported TB
Custom Tune
FAST 90
ZEX 125hp wet shot
08-31-2006, 08:19 PM #19
- Oct 2005
- nj
Turbos are headaches, I'd rather just run juice instead. The car can be streetable without the hours of tuning.
http://s63.photobucket.com/albums/h1...gAnch=imgAnch8
08-31-2006, 11:07 PM #20
- May 2006
- Oklahoma
red- 1973 TransAm
I'm going to stay with the 455, with a single or twin turbo, Mega-Squirt EFI.
Looking for about 750HP. Forged pistons and rods
As a street car and RPM Max 5800 what would be the best choice for a Pontiac 455 Single or twin ?
I would like to have a good turbo setup with out buying top of the line stuff.
The car is not a daily driver and does not have factory A/C, that is one of the reasons I was thinking single turbo on the passenger side.
1972 Pontiac GTO - Gee ...! No, G-T-O!
By Ed Blown Vert in forum GTOReplies: 0Last Post: 07-07-2014, 05:10 AM -
1972 Pontiac Grand Prix - State Of The Art, Circa 1972
By Ed Blown Vert in forum Firebird / WS6Replies: 2Last Post: 10-25-2012, 03:23 AM -
1972 nova with 1998 ls1
By nova1972 in forum New Member IntroductionsReplies: 5Last Post: 01-24-2010, 12:24 PM -
1972 Chevy Nova SS - Red Hot!
By Ed Blown Vert in forum Camaro / SSReplies: 1Last Post: 11-05-2008, 03:10 AM -
1972 firebird
By kris6273 in forum Classic MuscleReplies: 8Last Post: 04-20-2008, 01:40 PM
