Results 1 to 11 of 11
    Junior Member JBZ28's Avatar
    Sep 2010
    Carmel, NY
    1999 z28 camaro
    Floppy gas pedial
    I have a 99 z28 Camaro and my gas pedal seems to be really easy to move back and forth with my foot like there is allot of slack in it. Is there any way this can be fixed.
    Member zeetwentyeight's Avatar
    Aug 2009
    A, A
    1998 Camaro Z28
    Quote Originally Posted by JBZ28 View Post
    Mine does the same thing, it made me wonder if my car was even going WOT, so i checked the throttle body while someone held the pedal to the floor and it was still all the way open.
    Sep 2010
    Carmel, NY
    1999 z28 camaro
    Quote Originally Posted by zeetwentyeight View Post
    I wonder if its just made crappy or it's a mechanical problem
    Aug 2009
    A, A
    1998 Camaro Z28
    I think they made it that way for a reason. My thinking is they did it for when you pull the floor mats out, that would be my guess.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    do you mean it moves side to side a lot?
    Sep 2010
    Carmel, NY
    1999 z28 camaro
    no it's loose front to back, if put my foot under it with almost no pressure at all i can move like an inch or so back and forth like its not held in place by tension like the brake and clutch. Also it's allot farther down than the brake pedal.
    Sep 2010
    Carmel, NY
    1999 z28 camaro
    then why don't the break and clutch do that
    Aug 2009
    A, A
    1998 Camaro Z28
    Gas pedal is supposed to sit lower than the clutch and brake pedals
    Madison, WI
    2001 Silverado Z71
    the gas pedal is supposed to flop around if you put you toe under it.
    Sep 2010
    Carmel, NY
    1999 z28 camaro
    I know bot its like abnormally low
    Sep 2010
    Carmel, NY
    1999 z28 camaro
    why?
  1. Floppy Shifter
    By SHines-IT in forum Almost Anything Goes
    Last Post: 08-01-2010, 09:37 PM
  2. Too floppy
    By pajeff02 in forum General Help
    Last Post: 09-04-2009, 01:30 PM
  3. Is your rear bumper floppy?
    By third_shift|studios in forum Firebird / WS6
    Last Post: 10-02-2006, 05:16 AM
  4. I need help installing a 3.5 floppy drive in PC
    By Mike Hawk in forum Almost Anything Goes
    Last Post: 03-12-2006, 09:06 AM
