Thread: Tires/Tubes question
07-03-2006, 09:29 PM #1
MT and Hoosier both say that certain lines fo their tires require tubes... yet Weld says that the Pro Star line of wheel is garanteed tubeless. which one should i listen to?
07-04-2006, 01:32 PM #2
tire manufacturer. i have run tube type tires without tubes. just have to keep a check on the air pressure.
07-05-2006, 05:35 AM #3
at the track, i take my pressure down to about 10psi. would that be too low to run tubeless?
07-05-2006, 01:56 PM #4
yes. anything under 15psi and the bead could pop off the rim.
07-05-2006, 03:31 PM #5
thanks for the info
question regarding rims and tires?
By bezerker03 in forum Wheels and TiresReplies: 4Last Post: 10-30-2010, 09:28 AM -
Question: Question about new rims and tires.
By Odawg1 in forum Wheels and TiresReplies: 5Last Post: 09-01-2010, 10:43 AM -
Ls6 coolant tubes question
By km346 in forum External EngineReplies: 40Last Post: 04-27-2010, 07:23 PM -
clearance question for pro-kit drop and long tubes
By 00maroz28 in forum Suspension and HandlingReplies: 9Last Post: 04-25-2007, 07:11 PM -
Question about the treadwear on tires...
By NeeD4SpeeD in forum Wheels and TiresReplies: 8Last Post: 10-10-2005, 11:13 PM
