Thread: what size cam?
06-24-2007, 08:13 PM #1
what size cam?
i have an 01 ws 6 and in the market for a cam.. ive got slp LTs, and an slp lid, k & n air filter.. i want to retain drivabilty any advice on a good cam and what size?? i will probably have the heads ported and polished ,, or new heads later.. thanx
06-24-2007, 08:21 PM #2
cam
i also plan on an intake and larger throttle body too.. later.. any suggestions on that??
06-24-2007, 08:24 PM #3
I personally would do heads/cam/double timing chain,ls6 oil pump all at the same time. You can get a package deal from Texas Speed. They have the MAGIC STICK 3 or 4 cam which is awsome from what I read.
06-27-2007, 07:34 AM #4
- May 2007
- So*Cal
I would do a heads/cam combo at the same time. It's better to be able to match them together at the same time compared to doing one or the other and then trying to match up later. The latter would most likely be a more expensive route for you.
For example, say you went cam only. Most want a monster cam to give them the HP/TQ numbers. With that said, it's fine. However later when you want to add your ported heads you will most likely have to flycut your pistons to clear the cam. Now you added extra costs for new pistons, flycut labor, and/or a new cam altogether.Eric @ WAR (Formerly Eric @ DMS)
06-27-2007, 09:21 AM #5
- Sep 2005
Is your car manual or auto? Do you plan on tuning right away?
06-28-2007, 01:04 PM #6
its auto.. and i plan on tuning right away
06-28-2007, 01:19 PM #7
I have a 01 WS6 also I have a custom comp 228/236,578/588 114 cam and stock heads that have been ported and polished with manley valves,dual springs and all the standard upgrades to support the cam. I got 393 rwhp and 352 tq on a Mustang Dyno.This was done a few years ago and the car still runs great.I also have a 3400 stall and 12 bolt with 3.73 gears. Idles at around 900 rpm no issues at all.
06-29-2007, 05:42 PM #8
ther are acouple of cams to choose from
through vinci the XXX or 056
http://vincihighperformance.com/CAMS...%20LS1%202.htm
through thunder racing the TR214/220-115 or 224/224-114
http://thunderracing.com/catalog/?ac...&vid=3&pcid=51Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
LS1 valley cover bolt size, what size?
By Blue28 in forum External EngineReplies: 1Last Post: 10-03-2009, 05:47 PM -
Help: Cam size help
By Sarge91 in forum Internal EngineReplies: 15Last Post: 06-21-2009, 09:07 PM -
Question: What size wheel studs? OEM size?
By x10-wakerider in forum Wheels and TiresReplies: 2Last Post: 06-20-2009, 08:26 AM -
What size?
By clg82 in forum Wheels and TiresReplies: 2Last Post: 06-11-2007, 03:10 PM -
What size?
By clg82 in forum Wheels and TiresReplies: 1Last Post: 06-05-2007, 07:37 PM
