Results 1 to 15 of 15
Thread: A few header questions
11-21-2011, 09:58 PM #1
I am looking for a set of headers for my '01 WS.6. I am looking at either the Kook's or the Hooker Super Comps and matching them with a true dual system. I don't know if I need the AIR and EGR stuff on them. Does anyone know if you need these things to pass emissions tests or is there a way to bypass those? I would also like to not use cats if I don't have to but since it is a street car I would like to keep it as legal as possible. Any input would be greatly appreciated.
Thanks All!
11-22-2011, 05:33 AM #2
- May 2009
- college station, tx
sold: 1999 firebird- 1998 Trans Am
you have an '01, so you dont have to worry about EGR because you dont have it, all your headers have to have are 02 sensor bungs.
if you are worried about passing emissions buy some highflow cats, can't say how well they work, others on the site have them though..
11-22-2011, 05:52 AM #3
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
As Justin said, you can have the SES light tuned out for removing the AIR system, and run without it. I'm not sure how strict PA is with emissions, but you may need to keep it to pass. I know quite a few members on here are in PA, so they may be able to clear that up.
11-22-2011, 05:58 AM #4
Thanks fellas. That's good info. I didn't know my car didn't have EGR.
11-22-2011, 05:07 PM #5
You can pass OBD emissions with air codes turned off and rear o2 sensors tuned out, but you will fail a strict visual inspection if they do those in PA.
_______________________________
2001 Black SS Vert with bolt-ons, 228R cam, 380 RWHP
11-22-2011, 05:15 PM #6
Welcome to the site Brian! Whereabouts in PA?
I went with Kooks LT's on our car and their catted Y-pipe. Figured I would keep it at least semi-legal, even though I did ditch the secondary air system and tuned out the rear O2 senders. Kooks is a bit more money, buy the fit and durability of stainless is well worth it.
11-22-2011, 06:56 PM #7
Thanks Jeff! I'm in the Harrisburg area. With what everyone has said here I am gonna go with the Kooks LT's. Do you pass emissions tests with the setup you're running with?
11-22-2011, 07:41 PM #8
Also, does anyone have any suggestions for the best price on Kooks headers? I usually shop with Summit which has them for 850 but if someone knows of a better deal out there..let me know!
Thanks again all!
11-23-2011, 03:06 AM #9
I ordered mine from KY Speed back when they sponsored the site.
Fortunately, we do not have emissions testing in our area -- I'm a little over 2 hours north of you. Next year, if you ever get the urge to run at the track, we have a place in Beaver Springs about 2 miles from the strip. You are more than welcome to join us on a test and tune day.
11-23-2011, 04:57 AM #10
Ya I forgot they don't require emissions upstate. And thanks for the offer. I might take you up on it someday once I get a little more work done to the car. By the way, what primary size did you get? Just curious.
11-23-2011, 07:17 AM #11
- May 2010
- Wilkes-Barre, PA
Black/Black- 98 WS6/04 Sierra Dmax
Dauphin county has an on board diagnostic OBD inspection and maintenance check and gas cap test. So as long as the AIR is tuned out you should pass the emissions test.
Callies 383, Trick Flow 225, Rapid Motorsports Dominatior 2 X cam, ls6 ported oil pump,42lb injectors, FAST 92/92 , ASP underdrive pully, eletric water pump, Pacesetter LT's, Pacesetter ORY, Magnaflow catback, e-cutout, Yank SS 3600, Performabuilt stage 2 4l60e, Strange S60 ,4.10s, Detroit Truetrac, (UMI) - Adj. LCA, Adj. tunnel mount torque arm, Adj. panhard bar, Drag bar, subframe conectors, shock tower brace. 465rwhp-438rwtq 11.09@119.90.
11-23-2011, 07:24 AM #12
- May 2010
- Wilkes-Barre, PA
Oh and Beaver Springs is a great time
11-23-2011, 07:58 AM #13
Ah good to know. Ya I've heard it's a blast. I definitely want to get my rear end done first so I don't snap an axle like my buddy did there. Thanks!
11-23-2011, 08:23 AM #14
- May 2010
- Wilkes-Barre, PA
Yeah I hear ya, I didn't snap an axle but I hurt the diff. I was loosing posi during my burnout. Just ordered my new rear last week so ill be ready for beaver in the spring time.
11-23-2011, 08:55 AM #15
I went with the 1-7/8" primaries to allow for future upgrades -- cam and heads. Might just happen this winter if all goes well.
1 7/8 header questions
By black2kSS in forum External EngineReplies: 6Last Post: 04-10-2011, 11:41 AM -
Header Questions
By Auto in forum External EngineReplies: 6Last Post: 02-04-2009, 02:41 AM -
LT1 header questions
By vecaj in forum LT1Replies: 28Last Post: 01-19-2007, 01:58 PM -
Header questions
By grandkodiak in forum LT1Replies: 4Last Post: 06-21-2006, 01:40 AM -
header questions??
By Irman393 in forum External EngineReplies: 19Last Post: 09-04-2005, 10:59 AM
