Thread: Running Rich
07-15-2010, 02:26 PM #1
Running Rich
Just finished heads, intake, injector, cam, long tube install. I set the injector slope with my Predator(saving up for HPT). After the car warms up, I run the Real Time Data on the Diabloa and my stft are running wild. One bank will start at 1-2 then spike up to 25 for a short time, then go back to 2-5. Then the other bank will do the same, but they alternate. I've read all the threads that point to a gas leak, so I welded the whole system. I see/hear/feel no leaks. Also, I've checked all the vacuum lines that are still connected. No leaks there either. Only codes I am showing are Absolute Intake Pressure, and sometimes a bank 1 O2 heater. That one is incosistent. It doesn't always show. I would automatically assume it was a bad O2, if the numbers weren't swapping back and forth. I can't even swap the O2's side to side to test. Any thoughts?
07-15-2010, 07:21 PM #2
- Apr 2008
- Madison, WI
Almost seems hopeless trying to diagnose a car that isn't even tuned. I'm not sure I wanna even make a suggestion...but I'll ponder this for a while and let you know if I can think of something
07-16-2010, 03:34 AM #3
07-16-2010, 04:36 AM #4
- Jan 2006
- Shepherd, Michigan
i dont think it is even worth messing with until you get a real tune.
07-16-2010, 08:23 PM #5
07-17-2010, 05:20 AM #6
07-17-2010, 09:54 AM #7
Be sure to read the PCM and save the current tune as a starting point. There's lots of good demos on the HP Tuners site on how to do things. Another option is to request a new base tune from Frost for a similarly outfitted engine -- that will at least put you in the ballpark and the car should run decent enough (barring mechanical or electrical issues) to start logging things.
07-17-2010, 10:43 AM #8
What I was going to do is revert to the factory tune in the diablo, and save that. That way I would have that if I every changed back to a mild cam and smaller injectors. I looked through the tune repository(depository?) and couldn't find anything that would be close. I assume Frost has many more options than that. Is it a full file, or just certain cfg files that need to ne changed?
Question: Why am I running rich?
By clg82 in forum General HelpReplies: 35Last Post: 07-22-2008, 12:37 PM -
Running WAY Rich
By Krazy351w in forum General HelpReplies: 6Last Post: 06-05-2007, 09:28 AM -
Running rich... what to do?
By Red00WS6_DreamBird in forum General HelpReplies: 4Last Post: 11-05-2006, 05:50 PM -
im running rich
By PgaNick in forum General HelpReplies: 7Last Post: 08-02-2006, 08:16 PM -
running pig rich
By z28rktec in forum General HelpReplies: 8Last Post: 01-26-2006, 07:45 AM
