Results 1 to 20 of 20
Thread: Exhaust with headers
06-04-2013, 07:07 AM #1
I bought my 98 Z28 in october, and the guy threw in eldelbrock shorty bolt-up headers in with it, i was wondering what type of exhaust would sound really good with the headers hooked up, i was looking into offroad H and X pipes but im not sure if that would be way too loud, anybody have any ideas?
thanks - Kris
06-05-2013, 01:14 AM #2
- Apr 2007
- Forest Lake, MN
maroon- 2000 Z28
H and X pipes more even out the exhaust pressure from each bank on a true dual set up. I'm guessing you run emissions in WA so you're gonna keep the cat's on there to pass. I liked the Hooker cat back. Quiet with a lower rumble when idle but screams when you get on it.
2000 Z28: Accufab 4150, Vic Jr. 150 shot, Patriot stg 2 heads, big cam, FLT Stg VI 4L60, S60 rear. Waaay more stuff to list. 3100 LBS.
06-05-2013, 03:33 AM #3
Always been a fan of the Magnaflow systems. One of the first mods on our car was the installation of a catback. With, or without, cats these systems have a great sound.
06-05-2013, 03:58 AM #4
- Jan 2012
- Alabama
Bright Rally Red- 2001 Chevy Camaro Z28
+1
I have Magnaflow on my car and really like the way it sounds. It's not obnoxiously loud, but it's not quiet, either. Sounds great coupled with a pair of long-tube headers, as well
Having said that, exhaust sounds are pretty subjective, and what sounds good to one person may not sound good to another. If you know anybody with an LS1 and an aftermarket exhaust system, go take a listen and see if you like what you hear, then find out what exhaust system they are running. Honestly, though, you really can't go wrong with a cat-back from any of the well-known exhaust manufacturers.2001 Chevy Camaro Z28 A4
SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
06-05-2013, 04:41 AM #5
Honestly you are better off selling those headers. The shorty headers will give you such minimal gain that it isn't even worth installing. Just bolt up a cat back to the factory Y, and when you want to do more, then go with long tubes.
- - - Updated - - -
06-05-2013, 10:49 AM #6
Borla! Cat back 3" Adj...perfect, and I have shorties and got 12 HP out of them over the Stock manifolds...not longtube power but easy and hook up to the cats and no codes!!!
2001 WS.6, Borla Adj cat back exhaust, Borla Twin Tips, BBK shorties, High Flow Cats, Y Pipe, UMI strut tower brace, SLP Lid + K&N Filter, Smooth bellow,85mm MAF, Polished Throttle Body, Hurst gumball knob, Hood wrap with Black Stripes, Frost Tune.
06-05-2013, 01:34 PM #7
Thanks for the imput guys i'll do some pricing, and yes i have to do emissions this month... i might just cut those cats out as soon as it passes haha
06-05-2013, 03:40 PM #8
I would use those headers to rest the box of longtube headers on in the garage while you install the longtubes. A lot of work to put those shorties in for basically no gains. If you're doing the work you might as well get some HP out of it. How much money do you have to spend on a catback? Are you looking for badass or mild mannered? GMMG makes the baddest ass exhaust I've ever heard on a f-body. You pay for it though.....$750.
Check out ls1sounds.com and listen to a few set ups.
06-05-2013, 04:47 PM #9
06-05-2013, 06:28 PM #10
06-06-2013, 03:38 AM #11
For comparison sake, my understanding is that longtubes are generlly worth 20-25 hp together with an updated tune.
06-06-2013, 06:39 AM #12
06-06-2013, 06:44 AM #13
I believe you are right, and if there was an easier way to get it for the same or less money....
06-06-2013, 06:47 AM #14
And, those shorties will hold you back in airflow when you decide to upgrade heads and intake. Then, you will need to install the LT's to get your full benefit.
06-06-2013, 08:56 AM #15
I get your point AZ and agree, I'm just saying those of us who don't plan on or cant afford doing engine upgrades and continue to put bolt ons...it was just easy for me to change to shorties that bolted right in, unlike long tubes that require emissions changes to get rid of codes and clearance issues and new or no cats and new y pipe etc. He already has the shorties and I was just saying there not worthless and they are easy!!! They are by no means comparable to longtubes!!!
06-08-2013, 05:10 AM #16
- Apr 2007
- Forest Lake, MN
maroon- 2000 Z28
You planning on running cats though? Emissions won't pass you if you don't have them on the car.
06-08-2013, 09:34 AM #17
06-09-2013, 04:23 AM #18
06-09-2013, 09:45 PM #19
- Apr 2007
- Forest Lake, MN
maroon- 2000 Z28
Actually, since you're not cammed, you probably could pass the emissions test depending on how strict they are.
06-10-2013, 06:40 AM #20
new headers and exhaust are in
By cspeich2011 in forum Firebird / WS6Replies: 2Last Post: 06-05-2011, 04:03 PM -
So put my headers in.... my exhaust however.......
By 95camaroZNC in forum External EngineReplies: 15Last Post: 05-20-2010, 03:49 PM -
which headers/exhaust?
By TAallday in forum External EngineReplies: 2Last Post: 11-22-2009, 05:52 PM -
Headers and exhaust
By Blackout01 in forum External EngineReplies: 4Last Post: 09-07-2008, 05:28 AM -
Which of these headers/exhaust would be best?
By xinthenight in forum External EngineReplies: 7Last Post: 06-13-2007, 01:55 AM
