Thread: Repair my side skirt?
08-23-2005, 09:30 PM #1patricklee88Guest
Hey guys,
Awesome site you guys have here!! Well, the thing is I busted up the ?side skirt? (The very bottom of the right side of the car/the plastic piece underneath the door) on my right side pretty badly. There is a series of scratches on it, and it is messed up. So, I just wanted suggestions on how I should try and fix it? Perhaps, some advice on how to paint it or sand it and wat kind of paint to use? Any help is appreciated! Ill post pics once the sun comes up. Thanks guys!
-Patrick
08-24-2005, 03:34 PM #2
- Jul 2005
- Central TX
Sunset Orange Metallic- 2002 WS6
i have a drivers side rocker panel for sale
08-24-2005, 06:18 PM #3BeastGuest
If they are just paint scratches... you'll just have to get it sanded down and painted. Probably $60 - $80 at a local auto-body shop... however if the plastic is gougeed, it'll either need replacing, or you can try and use body filler, or ask the auto body shops what type of other fillers you can use to fix the gouges. Either way it'll have to be painted.
Mark
08-30-2005, 07:16 PM #4
- Central PA, USA
Red- 1995 Trans Am 6 Speed
Originally Posted by Beast
Good luck,
09-02-2005, 10:29 AM #5
i had a curb jump out of nowhere and hit my front ground effects and i took them off and sanded them with 2000 grit then i got the factory matching paint from duplicolor and the color match is perfect. to this day i cant tell they were re painted. if you want to try this yourself, then whats the worst that can happen if you mess up youd still have to have it professionally done. give it a try
Wanted: Passenger Side Skirt
By 1998 T/A in forum Parts Wanted / TradeReplies: 1Last Post: 06-02-2009, 05:34 AM -
WTB 2002 Z-28 RH Side Skirt
By Home Theater Sales in forum Parts Wanted / TradeReplies: 0Last Post: 09-06-2007, 12:52 PM -
Trans Am side skirt
By burnrubr88 in forum Parts Wanted / TradeReplies: 1Last Post: 06-28-2007, 06:57 PM -
Right side ground effects skirt coming off
By cobrahunter in forum Appearance SectionReplies: 0Last Post: 09-11-2006, 09:00 PM -
Side skirt problem
By cobrahunter in forum Appearance SectionReplies: 0Last Post: 06-09-2006, 01:29 AM
