05-22-2008, 05:24 PM #1
- CANADA
Red- 1998 WS6
Something isn't right with my clutch
When I am stopped and go to put it in first gear, I can hear a small clunk in my driveline (prob the rear end). It seems like my clutch isn't fully disengaging?? This is with the pedal to the floor. First gear seems maybe a touch tough to get into, maybe its just in my mind. But it really feels like the clutch is still grabbing slightly..
I just bought this car last week (30th ann. # 609)and it was supposed to have a new OEM clutch installed last year with very min. miles since the install..
Where do I start?! I honestly have no experiences with clutches.
BTW this is my 2nd Ls1 ws6, glad to be back!Last edited by Hodge98ws6; 05-22-2008 at 05:33 PM.
06-01-2008, 04:17 PM #2
- CANADA
Red- 1998 WS6
Any suggestion would be cool?!
06-01-2008, 05:26 PM #3
if the clutch is definitely new i would give it a good bleed and check out the hydraulics...does the pedal feel soft or ever have trouble coming back up?...ive had the same problem and it was cuz my master cylinder was junk, it was losing pressure and not allowing the clutch to fully disengage...but i would start with bleeding the system cuz that can do wonders sometimes and there is a sticky on here on how to do it i believe...also check if your clutch fluid is black or darker colored than normal
06-02-2008, 02:13 PM #4
- CANADA
Red- 1998 WS6
Thanks for the tips.. The pedal is firm, but has no issues with sticking or feeling soft.. Actually it is almost too firm.. The fluid did seem a little dirty. I'll flush it out and refill with fresh fluid. I'll search for the sticky.
Thanks,I hope its as simple as that.
06-02-2008, 05:30 PM #5
yea its right at the top of the manual tranny section http://www.ls1.com/forums/showthread.php?t=55824 good luck and dont worry if its a little dirty...my fluid was like black when a had bad hydraulics
06-05-2008, 01:20 PM #6
- Nov 2007
- SATX
Pewter- 2000 Trans Am
if the clutch fluid is dirty then it will a darker thicker color. normal color change is common and safe. Ive been running dark Hydrolic Fluid on my PTO for months and the only time I Re-fill it is because it had a leak somewhere on the system.
New Disc Clutch System News - What's New In Clutch
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 04-27-2010, 05:44 AM -
Had Clutch slave cyl, clutch master cyl, and Clutch kit installed now I got problems
By 7camaro7 in forum Manual TransmissionReplies: 21Last Post: 12-13-2007, 07:41 PM -
Tranny, Clutch, or Clutch Hydraulic System?
By IZNUTHN in forum Manual TransmissionReplies: 2Last Post: 07-31-2007, 06:13 PM -
clutch locks up 1st gear in traffic while riding clutch
By Trixter in forum Manual TransmissionReplies: 9Last Post: 04-22-2007, 09:01 AM -
z06 clutch for sale, pressure plate clutch disk and flywheel
By themack56 in forum Parts For Sale / TradeReplies: 2Last Post: 07-06-2006, 07:15 PM
