Results 1 to 3 of 3
Thread: No Fuel Pressure
02-04-2024, 09:04 AM #1
- Feb 2024
- Pa
Black- 1998 trans am
No Fuel Pressure
HELP. Let me start by saying everything was working fine until I installed an LSA supercharger with ls9 fuel rails on my 1998 LS1. Now I have zero fuel pressure. The only thing fuel related I unhooked was the fuel rail hose. Whats weird is if I jump the relay my pressure spikes up to 100. Put the relay back in and its zero again. I have swapped out fuel pumps, fuel pressure regulators, relays, injectors and my fuel filter. Nothing...There are no kinks or anything in my return line and like I said all was well before. Any thoughts I would greatly appreciate it as im stuck.
02-06-2024, 04:10 PM #2
- Feb 2024
- Pa
Finally got fuel pressure and the car started then died after 2 seconds. Tried restarting and nothing. I figured my plugs were soaked but they were BONE DRY. Injector coils have 12v, fuses and relays replaced. What else could cause the injectors not to spray? VATS are disabled .
02-08-2024, 02:48 PM #3
- Feb 2024
- Pa
threw a noid tester on it and when I crank the engine it doesn’t light up. I checked the coil with a multi meter and I’ve got 12.19 v with KOEO. What does that mean?
Wanted: anyone have a air fuel and fuel pressure gauges
By 01SOMSS! in forum Parts Wanted / TradeReplies: 0Last Post: 05-06-2008, 11:30 PM -
Stock fuel pump/ how much fuel pressure can I run...
By jmangler in forum LT1Replies: 3Last Post: 10-02-2006, 06:23 PM -
What fuel pressure should I set my fuel pressure safety switch at?
By JAvery20 in forum NitrousReplies: 3Last Post: 04-01-2006, 03:59 PM -
Looking for gauges! nitrous pressure, fuel pressure!
By texasss in forum Parts Wanted / TradeReplies: 2Last Post: 10-29-2005, 09:05 AM
