Results 1 to 15 of 15
Thread: hatch release still won't work
02-16-2009, 08:12 AM #1
my 2000ss has the dreaded hatch problem, it only half releases when you try to open it and you have to keep pressing the button to release it. I have tried everything, including adjusting the rubber bumpers, adding a second release spring and adding a stronger spring in replace of the stock one. It still works less than 50% of the time. Really pissing me off now.
02-16-2009, 08:44 AM #2
- Feb 2008
- Palm Beach, FL
440 RWHP / 410 TQ- 2000 SLP CAMARO SS
Rip it off and throw it thru a window! It will make you feel A LOT better. Your trunk still won't work, and you will need a new window...BUT, you will feel a lot better.
02-16-2009, 08:54 AM #3
I think there is a kit for that? I am just starting to have the
same problem when it is cold. Someone will post some good info
just give it time!
02-16-2009, 09:34 AM #4
My wifes 2000 had the same problem when we bought it. I fiddled with the rubber bumpers as you did with no results. It wasn't until I adjusted the latch itself that fixed 90% of it. It was livable but still wasn't just quite right yet.
From there I looked into the various ideas and fixes. I didn't really like the piggy back spring idea so....
I took the mechanism apart, welded the hole on the spring arm shut and redrilled it as high as I could,,,about 1/8 inch from original location for a little more spring tension. After grinding the weld flush and repainting it looks factory.
So far it's been great. I am thinking though if I need more tension I am going to straighten that spring arm. It seems to be made with a slight bend at the pivot point. Straightening that by cutting a slot and rewelding again would give me even more tension. So far this hasn't been necessary but it's the next direction I'll go if the problem comes back again.
02-16-2009, 01:13 PM #5
- Feb 2006
- Orange County, NY
Do the gas struts still hold the hatch up? Have you tried lubing the latch mechanism?
02-16-2009, 01:27 PM #6
yes, struts still good and I lubed locked mech.
02-16-2009, 06:31 PM #7
- Mar 2007
- Omar's Tittie Taverna & Grill, Deh Rawod
18D Cock Diesel- 1999 Z28; 98 SS #2043 RIP
Get a new latching mech from the stealership?
"I am the executioner. When a crime is committed and the exalted state does not take vengeance nor move to punish, then comes time for the executioner to declare himself. I have waited long enough. The criminals are hereby sentenced to death. By fire. By earth. By water."
02-16-2009, 09:42 PM #8
- Jun 2007
- corona ca
white, white and pewter- Rip99SSA4,74Z28M4,02SSM6
no new release mechanism needed, just go to lowes or home depot, and grab a spring the same length as the spring on the mechanism behind the carpet, then piggy back the original spring with the newer heavier duty spring and your done.
hope this helps good luck
02-16-2009, 09:45 PM #9
02-16-2009, 10:13 PM #10
He's already added the second spring and replaced the original spring.
Same thing happened on mine.
Second spring still wouldn't pop it.
Ended up replacing the struts.
02-17-2009, 03:15 AM #11
did replacing the struts cure the problem?
02-17-2009, 04:25 AM #12
Yes.
My struts were strong enough to hold the hatch open, but too weak to lift it.
I had to lift the hatch by the spoiler when I opened it.
02-17-2009, 08:31 AM #13
02-17-2009, 10:10 AM #14
02-17-2009, 10:41 PM #15
- Jun 2007
- corona ca
gotcha, my fault for not properly or fully reading thru the op's first post, i did that while browsing thru and posting in a few threads
rear hatch fix didn't work
By rigdoctormark in forum General HelpReplies: 18Last Post: 12-06-2011, 01:32 PM -
Question: Hatch Release
By justinmc978 in forum Firebird / WS6Replies: 6Last Post: 05-07-2010, 11:13 AM -
Help: Hatch release problem
By mdcrabbie in forum Camaro / SSReplies: 37Last Post: 11-22-2009, 04:51 PM -
Help: Tecnical service bulletin on hatch release ?
By mdcrabbie in forum Camaro / SSReplies: 0Last Post: 02-25-2009, 05:33 PM -
Rear Hatch Trunk Release Button
By AFASTYZFR1 in forum Parts For Sale / TradeReplies: 3Last Post: 10-06-2008, 05:07 AM
