Results 1 to 3 of 3
Thread: BlueDriver OBD 2 smog readiness?
08-18-2016, 06:40 AM #1
- Aug 2016
- Merrick,NY
- 2001 WS6
Hi all, I had run my 01 TA through a smog readiness check on my BlueDriver, and it had come up that it would fail based on a few issues, namely catalyst and oxygen sensor readings. I am assuming that if an inspection shop plugs into the OBD port they will perhaps see this and be forced to pipe it. I bought this car secondhand from a lady and I don't believe she had messed with the tune at all as the whole car is original up to the radio. Has anyone experienced any type of smog readiness check on their OBD reader and if so what has your experience with the smog inspection then afterwards?
Sent from my iPhone using Tapatalk
06-08-2017, 06:48 PM #2
- Aug 2016
- Merrick,NY
- 2001 WS6
09-22-2022, 05:51 AM #3
- Aug 2016
- Merrick,NY
- 2001 WS6
Tried to delete but couldn’t so if anyone comes upon this, here is an update. The car wound up with bad knock sensors and they were replaced per the TSB and an ls6 valley swap was done also. The prior owner might’ve had a mechanic clear the code before selling it. Long story short- runs great passes smog no codes.
Smog Cam
By seamurda in forum Internal EngineReplies: 38Last Post: 04-07-2010, 11:41 AM -
SMOG!?!??!?!
By wanna_lS1 in forum Firebird / WS6Replies: 0Last Post: 07-20-2009, 06:26 PM -
Question: Is there a readiness code for EGR?
By clg82 in forum Computer & TuningReplies: 5Last Post: 06-03-2009, 10:25 PM -
Question: GM Readiness
By OnEbAdReDSS in forum Computer & TuningReplies: 3Last Post: 03-20-2008, 03:30 AM -
car smog q's
By chad2000ss in forum Camaro / SSReplies: 3Last Post: 10-06-2006, 11:25 PM
