Results 1 to 1 of 1
Thread: Transmission Selection for LM7
12-05-2022, 12:02 PM #1
- Dec 2022
- Vermont
Purple- 1948 Chevy Coupe
Hey everyone,
New here! I beginning a frame off build of a 1948 chevy and upgrading to an LS setup. I already purchased the motor and a trans. Motor is a 5.3L Lm7. Unfortunately, I didn't do enough homework and purchased a 1998 4L60E (tag code 8CAD, 613CADY09465781) sounds like from a 1998 van. From my resent searches, it sounds like getting that mount up is a pain and I'm probably better off getting a different trans. I have located a 2wd 4L60E trans that I am told is from a 2007 Silverado (tag code 8CLD, 618CLD445120051). I would like to avoid buying yet another transmission that I'm going to have to worry about flipping. Everything I am seeing so far, it shouldn't be a problem and the only difference is that is has a ISS speed sensor that my ECM will just ignore. So my questions are:
1. Has anyone done this exact swap or can provide me a sanity check that these will be compatible?
2. Searching that 8CLD online, everything I am seeing says that is a 4L65E, not a 4L60E. The seller who does alot of demo work insists it is a 4L60E. I'm inclined to believe him, but it does confuse me. Am I missing something?
3. Is there anything else I am missing that I may run into and want to check out?
Thanks everyone, any info would be helpful.
Same as everyone else..... Cam selection
By 87dimeblazer in forum Internal EngineReplies: 4Last Post: 08-26-2012, 06:16 PM -
Help: GTO or Trans Am Transmission Selection--MY FIRST POST!
By GianoRanger2000 in forum DrivetrainReplies: 3Last Post: 12-11-2011, 09:51 AM -
03 Z06 Cam Selection(More of the same)
By BLACKNIGHT03Z06 in forum Internal EngineReplies: 4Last Post: 12-26-2006, 06:20 AM -
LT1 cam selection
By 98-LS1 in forum LT1Replies: 6Last Post: 06-18-2006, 02:35 PM -
Transmission Selection Question
By Capster78 in forum General HelpReplies: 3Last Post: 03-12-2006, 07:23 PM
