Results 1 to 19 of 19
Thread: Different Heads
12-30-2007, 07:08 PM #1
Different Heads
Can someone tell me whats the different between the 5.3, LS6, L92 heads.
1999 Trans Am, 333rwhp/345rwqt
12-30-2007, 08:00 PM #2
.100
72 cfm
65 cfm
.200
140 cfm
124 cfm
.300
202 cfm
160 cfm
.400
244 cfm
196 cfm
.500
280 cfm
220 cfm
.550
291 cfm
226 cfm
.600
304 cfm
229 cfm
100
67 cfm
61 cfm
.200
133 cfm
108 cfm
.300
194 cfm
147 cfm
.400
242 cfm
183 cfm
.500
274 cfm
205 cfm
.550
290 cfm
213 cfm
.600
296 cfm
220 cfm
Top specs are from Ls6
Bottom set from the 5.3
Correct me if I'm wrong, but it's just a bigger cfm.
12-30-2007, 08:10 PM #3
- Sep 2007
- Denton, Texas soon Lafayette, Louisiana
Blue- 2002 Z28 Camaro M6
Here are some specs if you look around you should find what you need. A bit more difference between the heads then just flow rates.
12-31-2007, 05:53 AM #4
- Oct 2006
- St. Clair Shores. Michigan
Try a search
But in a nutshell
The 5.3's are identical to LS1 heads except smaller chamber and valves
LS6 heads are a tuned up version of the LS1 head for better performance.
And the L92/LS3 head is the new Gen IV rectangular port head that out flows even the best aftermarket stuff. But won't work on LS1'sCraig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
12-31-2007, 09:31 AM #5
01-01-2008, 06:30 AM #6
- Jun 2007
- St. Pete, Florida
Silver+Black/Black+Silver- 1999 TA M6/03 GSXR 600
hmm glad you asked this, i was curious too
01-01-2008, 09:27 AM #7
01-01-2008, 02:35 PM #8
- Jun 2007
- St. Pete, Florida
what's the diff between the 1.0 LS6 heads and 2.5 LS6 heads?
01-03-2008, 12:52 PM #9
- Dec 2007
- Austin, TX
Pewter- 2002 Trans am WS6 T-top
That depends if you are buy a real cheap set of ls6 heads or going aftermarket pp stage2 5.3 heads. Check thunder hill racing and patriot performance.
01-03-2008, 01:12 PM #10
- Jun 2007
- St. Pete, Florida
but according to previous posts the LS6 heads flow better than the 5.3
and they have 2 options of LS6 heads : 1.0 and 2.5
01-03-2008, 01:32 PM #11
if you compare patriots listed numbers. Stage 2 5.3 heads flow 296 at .600 and stage 2 LS6 heads flow 304 at 600.
those are both with 2.02 intake valves. The stage 2.5 5.3 heads have 2.04 valves. I'm not sure how much extra flow the larger valves are worth but probably not a ton. Probably make them comparable to the LS6 heads with the 2.02's.
01-03-2008, 01:40 PM #12
- Jun 2007
- St. Pete, Florida
what about the stage 3 ls6 ? those seem to flow the best?
sorry don't know much about heads/cams at all..
01-03-2008, 01:49 PM #13
If you notice the bore size went up also. Just my personal opinion but if you want a good head just stick to the LS6 stage 2's. I also don't think there's a really huge difference between those and stage 2.5 5.3L heads. That's opinion of course.
01-03-2008, 01:57 PM #14
- Jun 2007
- St. Pete, Florida
Ok, I guess when it comes time to do heads/cam package i'll just ask them on the phone thanks for the info though
01-03-2008, 02:07 PM #15
- Sep 2007
I would do alot more then that, ask around and talk to lots of people, and don't forget to try to read as much about them as you can. Heads and cams can be intimidating at first, but eventually if you dive into the information and try to understand it will be easier to understand and you will end up getting something closer to what you want.
01-03-2008, 02:28 PM #16
I agree. Ask as many people as you can and make sure you have an understanding of what you're getting before you get it. I see that happen with cams. People just sorta go with the flavor of the month and when they get it they're disappointed. Bigger is not always better. You need to pick the setup that suites what you want out of the car and what works for you. If you put miles on the car and do a lot of stop and go traffic then a 248 duration cam with .6xx lift on a 110 lsa probably isn't what you're looking for.
01-03-2008, 02:46 PM #17
- Jun 2007
- St. Pete, Florida
Well as far as the cam goes, from what I've read I want a 228 with 112 lsa.. i drive the car everyday... and I know they have heads and cams packages, I figured if I were to ask them waht heads they would recommend for that particular cam they would point me in the right direction
01-03-2008, 05:00 PM #18
or they'll point you to whatever they have in stock. Maybe not true but just making a point. It's always best to know what you want going in and have an understanding of why you want it.
01-03-2008, 05:22 PM #19
- Jun 2007
- St. Pete, Florida
Yeah you're right, it's gonna be a few months before I start thinkin about gettin them though, so I have some time
Late-Model GTO Heads and Cam - The Voice Inside Our Heads, P
By Ed Blown Vert in forum GTOReplies: 0Last Post: 03-16-2011, 09:30 AM -
By Ed Blown Vert in forum GTOReplies: 0Last Post: 02-04-2011, 02:00 PM -
AFR heads VS. Ported and beefed up stock heads.
By hutcher04 in forum Internal EngineReplies: 10Last Post: 03-14-2010, 08:27 AM -
New Heads or Port/Polish Stock Heads?
By Black02LS1 in forum Internal EngineReplies: 32Last Post: 06-22-2007, 11:29 PM
