Thread: Fans not kicking on
09-28-2012, 06:14 PM #1
- Oct 2008
- Coral Springs, Fl
Fans not kicking on
Picked up a 98 z28 and am having an issue keeping the car cool. Main problem is the fans don't seem to kick on. Hooked up HPtuners to it and i can manually turn them on but they don't want to come on by themselves. Coolant temp reads fine so i'm thinking PCM. Anybody have any ideas before i go out and pick up a new computer?
Just to be on the safe side i'll be installing a new water pump and radiator but the fans are still my main problem.
09-28-2012, 06:21 PM #2
http://www.ls1.com/forums/f6/radiato...lution-169050/ Just a thought.
09-28-2012, 06:34 PM #3
- Oct 2008
- Coral Springs, Fl
Slightly different issue. What stumps me is the fans work and i can turn them on manually, but they should come on by water temp automatically. And the fact that they do work leads me to believe it isn't a wiring issue.
10-01-2012, 04:42 PM #4
- Jan 2009
- North Jersey
Have you checked the temp sensor in the head to see if it's bad?
10-01-2012, 07:09 PM #5
- Oct 2008
- Coral Springs, Fl
Temps read fine. I think what happened was i didn't get the car hot enough for the fans to kick on. I think the stock fan setting is about 225-226, i only let the car hit 224 and killed it. 226 seems high but i'll try and get her up to temps tomorrow and hopefully the fans kick on. AC doesn't work so the fan doesn't kick on with it on.
10-01-2012, 07:16 PM #6
Can you set the fans to come on before like at 200 so you wont have to let it get to 226?
10-01-2012, 07:26 PM #7
The PCM will command low speed fans ON at 108°C (226°F) and OFF at 103°C (217°F) and, high speed fans ON at 113°C (235°F) and OFF at 108°C (226°F).
Pretty sure that's correct.Boost gets you laid, unless your name is Jon.
10-01-2012, 07:38 PM #8
- Oct 2008
- Coral Springs, Fl
Yep Jon, think thats about right. I got it to 224 last time and thought it was high enough but i guess not.
And i might drop the temps but want to be %100 sure i'm keeping it before i use up some hp tuners credits.
Help: Ac compressor not kicking in
By cancam99ss in forum General HelpReplies: 9Last Post: 05-18-2013, 12:00 PM -
LT1 is kicking my ass!!!!!!!!!!!
By kensz28 in forum LT1Replies: 21Last Post: 03-06-2011, 10:28 PM -
Help...Transmission not kicking down in WOT
By rbruner10 in forum Automatic TransmissionReplies: 8Last Post: 02-02-2011, 05:20 PM -
Ok I am down,stop kicking me!
By cuervo25_1 in forum Almost Anything GoesReplies: 20Last Post: 06-30-2010, 02:06 PM
