Results 1 to 15 of 15
06-19-2010, 02:38 PM #1
Headlight Restoration... THE RIGHT WAY!!!!! Pics!
Hi Everyone!
I am new to the forum so I figured I would contribute a little something.
I recently bought a 2000 Camaro z28, and after I waxed it, I couldn't help but notice how dull and yellow the headlights were. I tried the toothpaste technique, and a turtle wax restoration kit. After no luck, I decided to cut the crap and do it right. Here's how it's done!
First off, here is what you're going to need to pull this off like I did...
1. Window Cleaner
2. Rubbing Compound
3. Polishing Compound
4. Plastic Polish (PlastX)
5. Metal file
6. 10mm wrench, or socket
7. Painters tape
8. Wet/Dry Sand Paper (Grits 220/500/1000)
9. Bucket
10. Any kind of buffer with buffing bonnet
11. Rag
12. Hacksaw Blade
Here are my headlights before. Keep in mind this is after I used the turtle wax kit, and toothpaste techniques, so they're not too bad.
06-19-2010, 02:38 PM #2
Step 1: Open your hood and unplug the wires attached to your headlights.
2nd Plug
06-19-2010, 02:39 PM #3
Step 2: Unbolt and remove your headlight. First grip the headlight and slide it towards the center of the car. It may be tough, but it will break loose and slide over.
This is the bolt to remove.
These are the hooks you need to slide inward.
Next push the inner part of the headlight through, pull from the inner part, and slide out the back part of the light. Be gentle with this step so you don't scratch your paint!
06-19-2010, 02:39 PM #4
Step 3: Mount your headlight in a vise of some sort if available; this will make the whole process much easier. Otherwise you're going to have to hold the light against a bench.
06-19-2010, 02:40 PM #5
Step 4: Remove Nipples. This doesn't need to be done, but it will make the other steps easier, and it makes your headlights look much more sleek.
Grip your hacksaw blade at each end, and gently work it back and forth until you remove all the nipples. Be carefull not to scratch up other areas of the lens with your blade. If you do, don't worry about it, you will get them out in the next steps. You may want to put you painters tape on the rubber, or on any areas you want to protect from the blade.
After I sawed the first nipple off.
Use your file to smooth out what is left of the nipples. Make sure you make them nice and flush, this way you will never notice they were ever there. Don't worry about scuffing up the plastic around the nipple, it will all be smoothed out in the next steps.
First nipple filed down.
Second nipple filed down.
Third nipple filled down.
All nipples removed
06-19-2010, 02:41 PM #6
Step 5: Sand down your headlight. Fill your bucket with water and cut pieces of 220 grit, 500 grit, and 1000 grit to put in the water. Write on the back of the paper what grit they are so you don't mix them up. Leave them soak for about ten minutes.
Start with your 220 grit and rub in a left-to-right motion. Spend the most time with 220, and focus on the areas where you removed the nipples, and where you have heavy oxidation and yellowing. This step is going to remove all of the damage and cloudiness.
After 220 grit sanding. Clean your headlight with window cleaner.
After 500 grit sanding. Clean your headlight with window cleaner.
After 1000 grit sanding. Clean your headlight with window cleaner.
06-19-2010, 02:42 PM #7
Step 6: Clear up your headlights by removing fine scratches. Use your rubbing compound, polishing compound, and finally polishing compound to really clear up your lens and make it shinny and clear.
First use your rubbing compound. Cover the whole lens with it, and then rub it around with your buffer OFF. After you have rubbed the compound in, then turn your buffer on. You're going to do three coats of rubbing compound. Thee first coat, use your buffer with low RPMs, second with medium RPMs, and the final with the highest RPMs. Remember that the more time you spend on these final steps, the better your headlight will come out. Remember to clean your headlight with window cleaner in between each step.
Next use your polishing compound. Do just as you did with the rubbing compound, only this time, do two coat, and both coat you are going to use maximum RPMs.
Finally, you are going to use your plastic polish to finish off the job. Make sure your light is cool. Rub in the plastic polish just as you did with the rubbing, and polishing compound. Do one coat of plastic polish with maximum RPMs. Your lens will show up super clear, and then immediately get a frost on it, this wipes right off with window cleaner.
After all steps.
Your headlights are all shinny and clear now. Use window cleaner to give them a final wipe down and clean the rubber. You may want to put a protective coat on them so they don't oxidize and yellow any time soon. The clear coat I used came with turtle wax kit I bought. I'm sure you can find another clear coat at your local automotive store.
06-19-2010, 02:43 PM #8
Step 7: Install your head lights. You are going to put your headlights back in, just the way you took them out, only in reverse.
First, slide the outside corner of the light in, then push the inside end in. Once again, be sure to be gentle, and work in the light, don't force anything.
Next, line up the hooks in the back of the light, and then slide them into place, sliding them outward, towards your fender.
Replace the 10mm bolt on the back of the light. Don't over tighten it, just snug it up.
You should park your car on a level surface in front of a wall and turn your lights on to make sure they are even. If they are not, loosen this bolt.
Once that is removed, you can adjust your light up or down since the bolt whole is elongated. Use something to compare your light heights on the wall, and when they are even snug up your bolt and you're all done! Clear headlights!
I really hope this helps! Post and let me know how it works, or if you have any suggestions to make it better or easier!
Mike
06-19-2010, 03:25 PM #9
Nice job. I used to do alot of headlights with my dewalt buffer till I found a cool attachment you can by at some auto paint stores. It's a 3" backing pad you attach to a drill and you can use the 3m 3" compounding and swirl remover pads. Also nice it you wanna polish taillights and hard to get area's around bumpers and spoilers. Find it's alot easier than my big dewalt.
Also your lights weren't that bad I have seen some worse another trick is wetsanding them with 400 to 600 grit and then just get a rattle can of clearcoat spray and let dry before reinstall. Most I just do right on the car. Next time I do a Camaro I'll take some pics. Usually I don't use rattle cans I use a gun with blk added to the clear to smoke them out.1998 Trans Am 85k miles.
02 Trailblazer -Sold
09 Ram 1500 CC - Sold
09 Cobalt SS/TC - Sold
06-19-2010, 03:50 PM #10
You did a great job! They look just like new
06-19-2010, 04:28 PM #11
Thanks for the positive feedback!
06-19-2010, 05:50 PM #12
welcome to the site, nice write-up!
06-19-2010, 09:57 PM #13
- Nov 2006
- Broken Arrow, OK
Good write up, added to the Museum
06-19-2010, 11:13 PM #14
- Feb 2010
- Greenwood, IN
Light Pewter Metallic- 2001 Camaro SS
great write up and awesome results!
2012 Regal GS
2004 Cadillac CTS-V (Sold)
2001 Camaro SS (Sold)
1999 Camaro Z28 (Sold)
06-20-2010, 07:48 PM #15
- Feb 2008
- Palm Beach, FL
440 RWHP / 410 TQ- 2000 SLP CAMARO SS
Nice Job!
There are currently 8 users browsing this thread. (0 members and 8 guests)
By rappin_ernie in forum Camaro / SSReplies: 55Last Post: 10-10-2011, 04:38 PM -
BG headlight restoration kit with pics
By WICKEDLS1 in forum Showcar and DetailingReplies: 15Last Post: 02-24-2011, 10:34 AM -
Headlight restoration (pics)
By GoFast908Z in forum Showcar and DetailingReplies: 6Last Post: 04-05-2010, 06:00 PM -
By LS1Jason in forum Showcar and DetailingReplies: 12Last Post: 04-14-2009, 03:53 PM -
Headlight Restoration Kit
By LETHALxLS1 in forum Showcar and DetailingReplies: 19Last Post: 08-17-2007, 09:15 PM
