Results 1 to 18 of 18
Thread: Pushrod Lengths
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    Pushrod Lengths
    What is the purpose of shorter pushrods? TSP offers them with their head/cam packages and I was wondering if I should pick up some shorter-then-stock pushrods...
    Do NOT pick up shorter pushrods unless you require them.
    Member Justin93's Avatar
    CANFIELD, OHIO
    PEWETER METALIC
    2002 CAMARO Z-28 M-6
    what would be the reason for going shorter though? Im curious as well
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    the length of pushrods depend on the amount of lift and duration on the cam and the compression ratio. if the cam has very high lift then the push rods need to be shorter so not to damage the valvtrain..ie valve kissing
    Actually...this isn't really the case.
    Unless you are pushing the limits of the clearance...and if you are, you should get pistons rather than shorten the pushrods to clear.
    My pushrods in the 402 are 7.325".
    Preload on my lifters is .060-.070 less than OEM. So that is the difference.
    Also had .020" milled off my heads, so that is a small amount of the shorter pushrod.
    Some heads have a higher rocker arm pedistal...which will require a longer pushrod.
    If you aren't sure or are wondering....measure.
    Lowered, HID's, tinted.
    Charlotte, NC
    Hugger Orange/W stripes
    1999 Z28 M6
    Well, now my head hurts!
    Shepherd, Michigan
    98' trans am
    screw you C
    screw you C
    Going with a shorter pushrod than required will just loose power and make a LOT of valvetrain noise. Also wear out the valve tips and rockers.
    Shepherd, Michigan
    98' trans am
    oh i agree with you on that..
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    They can be required when the heads have been milled as well, depending on application
    CANFIELD, OHIO
    PEWETER METALIC
    ya learn something new everyday here lol. thanks guys
    Laurel, Maryland
    2000 Grand Prix GTP
    So...5.3L heads with a MS3 cam (237/242 .603/.609") will or will not require shorter pushrods?
    You want proper preload on OEM lifters. .080-.100 preload.
    Most aftermarket cams actually have a slightly smaller basecircle than stock. In that case, a 7.410" would be ideal.
    I honestly think this is how some of these larger cams clear...the use of a pushrod that is just a little too short.
    Too determine base circle, call TSP.
    Why the MS3??
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    very incorrect. a pushrod will never correct piston to valve clearance issues.
    the purpose for shorter pushrods is to have correct lifter preload and geometry. the LS1 motor rockers are non adjustable. if you mill the heads, this brings the rockers closer to the lifter. this will put more preload on the lifters. to get back to the correct preload, you shorten the pushrrod the same amount you milled the heads.
    Shepherd, Michigan
    98' trans am
    yea i know that now..thanks for re-opening the wound robert
    Texas, USA
    2000 Camaro
    the pushrod length is only to keep your valvetrain geometry correct and to cut down on excessive wear on valvetrain components
    or atleast thats what i always thought...
    Laurel, Maryland
    2000 Grand Prix GTP
    Thanks for the responses guys, looks like I'll put it on the list of things to talk to TSP about.
    Why the MS3??
    Changing the role of the Trans Am...I don't DD her now, and if/when I get my new job, I'll be driving her even less because I'll be provided a car I can take home. So, she's going to be a track car, with the occasional cruise. Since I won't be working 3pm-11pm Tuesday to Saturday, I'll be able to go to the track more often.
    RI
    Mag Red
    2002 Vette
    Unless you have a stud mounted rocker (such as the Crane), pushrod length only affects lifter pre-load and will not change geometry. On a stud mounted setup, pushrod length affects both geometry and lifter preload.
  1. axle lengths?
    By southpaw0314 in forum Drivetrain
    Last Post: 10-18-2010, 01:18 PM
  2. Replies: 20
    Last Post: 03-14-2007, 09:08 PM
  3. Put bus lengths on a New Supercharged Saleen Gt
    By BlwnCamaro in forum Kill Stories
    Last Post: 03-09-2007, 11:47 AM
  4. Opinion - ideal 02 sim lead lengths
    By Steve Crowe in forum General Help
    Last Post: 01-06-2007, 11:15 AM
  5. Owned a 2002 C5 Z06 . . . by bus lengths
    By 996TTx50 in forum Kill Stories
    Last Post: 01-08-2006, 07:51 PM
