Thread: AC Problem 1998 Z-28
07-18-2009, 02:58 PM #1
- Jul 2009
- California
Red- 1998 Z-28
I have a 98 Z-28, and I only get hot air through the vents when AC is on. The compressor is functioning properly and the system is completely charged. If anybody knows a fix for this please let me know thanks
07-18-2009, 03:17 PM #2
- Jul 2005
- Jacksonville, FL
What are the low and high side pressures/sure it's charged correctly? Is just the center vents or all settings? First thing I'd do is check the static pressure (car off) if it's not cooling in any mode.
07-18-2009, 07:40 PM #3
You probly have a blockage somewhere.Mine was doing something similiar,turned out the dryer/reciever had some crap in it.Could also be in the orifice tube(easy fix).
07-19-2009, 12:23 PM #4
- Jul 2009
- Lincoln ne
red- 98 camaro Z28
another easy way to look for a blockage in your system is to see where you start to see condensation on the hoses. that will let you know where your restriction is. also check to make sure you have enough coolant in your radiator and enough air flow through your condenser. ie a bad cooling fan or a walmart bag stuck to it, i have seen it before. or to many bugs. good luck feel free to PM me with ?'s.
ISO 1998 trans am , camaro ls ECM and only 1998 ECM for ls1
By knock0991 in forum Computer & TuningReplies: 2Last Post: 07-24-2015, 06:59 AM -
Obama's Woman Problem A Problem Of His Own Making
By Ed Blown Vert in forum Political / Debate ForumReplies: 0Last Post: 01-14-2013, 02:50 PM -
Help: 1998 Trans Am A/C problem
By 90ARAPAJ in forum Firebird / WS6Replies: 20Last Post: 07-19-2011, 01:04 PM -
Help: 1998 Trans Am knock sensor problem
By 90ARAPAJ in forum Firebird / WS6Replies: 21Last Post: 06-29-2011, 06:05 PM -
1998 Z PCM problem..PLEASE HELP!!
By arthur in forum General HelpReplies: 26Last Post: 08-09-2010, 07:42 PM
