Results 1 to 20 of 30
Thread: High RPMs.
02-26-2011, 12:10 PM #1
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
High RPMs.
Hey guys. I need some help.
For the last few days my car Bern acting funny.
When I'm driving and I get to stop the car. When I hit the clutch. The RPMs stay high on 1500 rpms. After few seconds it goes down slowly to normal.
And some times go really low aroun 300 rpms seems like it's gonna turn off but then goes back to normal again.
And the gas mileage is bad. Since that is happening.
I cleaned the mass air sensor.
I checked for vacuum leaks. Nothing visible.
I dnt heard any noise of vacuum leak.
No engine codes.
What could it be?00 ss blk m6 " STOCK" strano springs, slp bilstein shocks, adj LCA, adj panhard bar, relocation brackets, 2 point SFCs welded,OEM zo6 rims black, magnaflow exhaust, CME exhaust,E/cutout, slp grille, custom front plate mount, HIDs, whistler mod, side moldings delete, slp air lid, ported and polished TB, strut tower brace, 3.73s gears, and some other parts to list!
02 tahoe Z71 blacked out
98 z28 red m6 sold
07 zx6r ninja flat/black sold
08 zx6r ninja sold
02-26-2011, 03:24 PM #2
- Feb 2010
02-26-2011, 03:30 PM #3
I would say 02 sensors but that would throw a code. MAF might be on its way out
I know MAFs don't always throw codes when they are garbage (Seen it first hand)┌∩┐(◕_◕)┌∩┐
wouldn't want to fight them!
02-26-2011, 03:37 PM #4
- Feb 2010
I thought it could be the MAF.
How can I make sure that's the problem?
O2 sensor should throw a code right ?
02-26-2011, 03:37 PM #5
Air leak after the MAF, vacuum leak, dirty throttle body and/or idle air control valve. All possibilities.
02-26-2011, 03:40 PM #6
02-26-2011, 03:53 PM #7
- Feb 2010
Tb is cleaned. Put it 500 miles ago.
It's ported.
No leaks between the tb and lid.
Nothing visual on the vacuum hoses.
When I put the ported tb. Everithing was fine.
It started doing this bout 40 miles ago
02-26-2011, 03:54 PM #8
- Feb 2010
How can I check air control valve?
02-26-2011, 08:56 PM #9
- Feb 2010
Dumb question. Could that problem be related to the stering pump?
I noticed right now that is making noise.
When I turns the steering wheel the rpms go higher than usual
02-26-2011, 09:03 PM #10
02-26-2011, 09:39 PM #11
02-26-2011, 10:24 PM #12
FYI, if you need p/s fluid, our cars use tranny fluid, NOT p/s fluid in the p/s system
02-27-2011, 12:02 AM #13
- Feb 2010
im a check the fluid tomorrow, so if it does need some auto tranny fluid is good right?
i remeber a while ago was making that noise and same thing happn, but after a while the noise was gone,
i think the pump is almost out
02-27-2011, 12:03 AM #14
02-27-2011, 05:37 AM #15
The IAC valve is located on the driver side of the throttle body. I have not had a problem with ours, so I am uncertain of the diagnostic procedure. I understand that they can get gummed up though and cleaning the sensor with a spray throttle body or MAF cleaner (preferred as it does not leave any residue) may alleviate the problem. Do you run a K&N or similar type air filter?
02-27-2011, 09:50 AM #16
02-27-2011, 10:15 AM #17
02-27-2011, 11:30 AM #18
Are you sure Cutlass? I was sure that GM uses ATF in pretty much all of their p/s units.
Either way it should say on the p/s resivior cap.
02-27-2011, 03:13 PM #19
02-27-2011, 05:13 PM #20
Only smokes at high rpms
By Fine 69 in forum General HelpReplies: 7Last Post: 01-09-2012, 04:45 PM -
RPMs too high
By Shudson105 in forum Automatic TransmissionReplies: 3Last Post: 10-07-2009, 05:43 AM -
Help!! High idle rpms
By degenerate in forum General HelpReplies: 4Last Post: 04-20-2007, 05:32 AM -
A lot of tapping at high RPMs
By Whiteboycntdnce in forum Camaro / SSReplies: 1Last Post: 04-02-2007, 07:34 PM -
high rpms out of gear
By iwantanls1 in forum Internal EngineReplies: 2Last Post: 10-10-2005, 01:20 PM
