Thread: A/C Compressor
10-08-2007, 10:21 AM #1
- Buffalo
A/C Compressor
Has anyone replaced an A/C compressor? Is it really difficult?
If I release the pressure in the system on the high and low side, how does the high side get it's pressure back? Is it automatic? I know we only charge the system on the low side, but how does the high side get recharged after the installation?
10-09-2007, 10:15 AM #2
- Jul 2005
- Jacksonville, FL
When you release the static pressure both sides vent all the refrigerant, when you charge it both sides fill simultaneously. I've never changed one on a car but do home AC - same principle.
10-09-2007, 10:20 AM #3
- Buffalo
ok .. sounds good, but can you explain this static pressure? be real specific if you can. where is static pressure? what is static pressure? I guess you mean the pressure in the system.. a? Just wondering about this term "static"
10-09-2007, 10:34 AM #4
- Jul 2005
- Jacksonville, FL
Static pressure is just the pressure in the system with the compressor not running. With it off both sides have equal static pressure, for example if you put gauges on both sides of the system they'll read the same, like around 100 psi depending on the ambient temperature, when the compressor starts the low side pressure goes down and the high side pressure goes up. Make sure at the very least you pull a vacuum on it before recharging.
10-09-2007, 01:18 PM #5
- Feb 2006
- Orange County, NY
you shouldnt just release the refrigerant. bring it somewhere and have them evacuate the system. it is illegal to just release it into the air.
10-12-2007, 10:19 AM #6
- Buffalo
is it necessary to put a new evaporator on it?
looking to buy air compressor
By 28Marcos in forum ToolsReplies: 16Last Post: 01-28-2011, 10:11 AM -
new air compressor
By Zboner in forum ToolsReplies: 3Last Post: 07-29-2009, 07:33 AM -
Air compressor
By tpilews in forum ToolsReplies: 23Last Post: 09-19-2007, 05:53 PM -
Need an AC Compressor
By TwistedSS in forum Parts Wanted / TradeReplies: 0Last Post: 03-20-2007, 12:09 PM -
New A/C compressor
By fastbuff in forum CorvetteReplies: 0Last Post: 01-13-2007, 06:09 AM
