Thread: ls-1 engine knock
03-14-2015, 08:59 AM #1
- Mar 2015
- chillicothe
black- 2000 formula firebird
ls-1 engine knock
I've got a 2000 Formula Firebird with the ls-1 in it and there a knock coming from what sounds like the 5th or 7th cylinder and i'm stumped on what it is the car has 185,XXX miles on it and runs like a raped ape but the knocking/ticking worrys me when i get in it. Anybody have any ideas?
03-14-2015, 02:10 PM #2
does it sound like this?
03-15-2015, 03:52 PM #3
^^ Scott is our local guru when it comes to solving mysterious engine knocks... he has heard them all.
There's a difference between a tick and a knock. Ticks are generally the result of valve train or an exhaust leak. A knock is a sign of something much more serious like a rod bearing on its way out.
03-15-2015, 05:42 PM #4
ls-1 engine knock
only because of bad luck.....
03-15-2015, 05:52 PM #5
Agree. I am still pondering that original issue you experienced... so unusual.
03-15-2015, 06:06 PM #6
- Jun 2011
- Branchville, NJ
Post a sound video and let's see what you have going on.
03-15-2015, 07:13 PM #7
03-16-2015, 02:54 AM #8
The one with the chunk of stuff floating around.
03-16-2015, 04:12 AM #9
ls-1 engine knock
that was because I bounced off the rev limiter a couple of times while doing a burn out.
97-98's have a crappy oil pump that was fixed on 99<.
03-16-2015, 06:31 AM #10
- Mar 2015
- chillicothe
it sounds like the video but a little quieter ill post a vid later if i can the noise differs in the loudness day to day if that makes sense
03-16-2015, 07:06 AM #11
If it's like in my video then the more you run it the louder it will become. It will also lead to a very expensive fix.
You can do a couple of things here.
Option 1 - get the car up on some stands, use a long screw driver or a piece of a cut down broom handle with the motor running place the screw driver/broom handle against the oil pan, side of the block if possible. Listen to see if you here the noise.
or
option 2 - Drain oil into a clean pan. Look for shinny speckles or even metal flakes. Next pull the oil filter and carefully cut it in half. Look in the filter for the same thing.
Each one if positive, confirms you have either a spun bearing or bad rod. Either one will require an engine pull. Better to do now then later, you might be able to save the crank however, keep running it for too long and you'll be looking for a new crank, rods, bearings. Push it too hard and then it will be a new motor as well.
This is what happens when it gets pushed too hard.
Here's where a chunk of the block blew internal. It was at the #4 cylinder.
No clue what this came from but it was bouncing around the block. the quarter was to show a size comparison
One of many bearings trashed.
This was #8 piston, #7 look the same.
All the LS1 damage was #7 & 8 pistons destroyed, Rod bearings - all except #1 & 2 spun, Main bearings 3-5 damaged. Crank - 3, 7, & 8 journals destroyed beyond repair.
Fun, fun times.....Last edited by SMWS6TA; 03-16-2015 at 07:08 AM.
03-16-2015, 09:58 AM #12
- Mar 2015
- chillicothe
After listening to it a bit and comparing videos i geuss its more of a tick but still doesn't sound im gonna post a video about 4:00
knock knock...who's there? wait...engine knock...
By jiveass in forum Internal EngineReplies: 60Last Post: 04-26-2011, 07:04 AM -
help engine knock 6.o L
By chrisnichols in forum General HelpReplies: 0Last Post: 01-25-2010, 01:41 AM -
Knock in New Engine?
By Ed Blown Vert in forum Internal EngineReplies: 10Last Post: 09-27-2009, 08:05 PM -
Help: engine knock
By Incubbi_8788 in forum General HelpReplies: 0Last Post: 07-20-2008, 07:05 PM -
Does Your Ls1 Have Engine Knock [yes-no ]
By Z ROADSTER in forum Internal EngineReplies: 12Last Post: 10-08-2007, 10:20 AM
