Results 1 to 3 of 3
05-01-2021, 10:16 AM #1
- Nov 2005
- Texas
Red- 2001 Camaro SS
Running the wiring for A-Pillar gauge pod
I'm installing some a-pillar gauges on my 2001 Camaro SS. I'm curious if there's any recommendations for where or how to run the wires through the firewall? The AFR gauge has a nearly 3/4" connector, so I need more than a tiny hole. I did this on my S10 and there was an easy spot to drill a role, but the Camaro is definitely tighter.
Thanks,
Scott
05-01-2021, 12:10 PM #2
Scott,
Had the same issue and I did not find a good solution either. I thought about cutting the wire and reconnecting it so I could keep the size of the hole small but given the wires are pretty fine I decided to leave the wire alone and ran a pilot hole through the firewall with a 1/4" bit then enlarged it slowly using a stepped bit until it was just large enough to get the wiring through. Then I filled the hole with a rubber plug from the local auto parts store that I split around the wiring to prevent chafing and fill the gap and hit it with black RTV on both sides to ensure it stayed sealed.
SteveATI Procharger, SFCs, Y-pipe, LM2, BBK Shorty Headers, Corvette N73 Magnesium Wheels, 4th Circle Designs Stripe and Overlay kit
05-01-2021, 07:58 PM #3
- Nov 2005
- Texas
Red- 2001 Camaro SS
For Sale: double gauge pillar with gauges
By Kaotic_ws6 in forum Parts For Sale / TradeReplies: 3Last Post: 12-24-2009, 10:08 AM -
BOOST gauge, FUEL PRESSURE gauge, dual pillar pod
By onefastbird! in forum Parts Wanted / TradeReplies: 1Last Post: 04-26-2007, 08:31 PM -
Dual pillar gauge pod for HARDTOP
By onefastbird! in forum Parts Wanted / TradeReplies: 0Last Post: 12-11-2006, 02:14 PM -
A-pillar Gauge Pics
By SSNAKEATER23 in forum Appearance SectionReplies: 1Last Post: 05-13-2006, 08:06 PM -
Pillar Gauge Pod?
By x10-wakerider in forum Appearance SectionReplies: 4Last Post: 08-24-2005, 04:20 PM
