Thread: Drill mod on '01?
03-20-2009, 07:10 PM #1
- Jun 2007
- aurora
Drill mod on '01?
Ok, I am confused. After searching on the forum I come to the conclusion that if you have manual, you should do the drill mod. I also heard that if you have an 01-02 you don't have to do the mod. I have '01 T/A and I am about to change the oil. My questions is should I do the drill mod? Thanks
03-24-2009, 04:54 PM #2
- Jun 2007
- aurora
So no one?
03-28-2009, 02:26 PM #3
- Sep 2005
- MIchigan
Navy Blue Metallic- 2000 Camaro SS
you do not have to do the drill mod if you have an 01-02 car only 99 and under the newer (01-02) cars have the updated hydraulics
03-28-2009, 04:49 PM #4
- Jun 2007
- aurora
03-28-2009, 05:15 PM #5
what is this and what about a 2000 ss camaro
03-28-2009, 05:44 PM #6
- Apr 2008
- Madison, WI
I'm not sure this is accurate but I believe all ls1 fbodies have the restriction and can benefit from the drill mod.
03-28-2009, 08:55 PM #7
I beleive all the LS1 4th gens have the restriction in the line that needs to be drilled.
As far as updated hydraulics,,,the 01 and 02 cars are supposed to have a different slave cylinder, and that must be all that is sold nowadays because when I checked into it there wasn't a supplier at all that knew there was even a difference
My wifes is a 2000 SS and I did the drill mod on it anyway, even with the newer slave cylinder and LS6 clutch setup because clutch action still wasn't right.
It wasn't until I installed an adjustable master cylinder that the clutch finally started acting like it should.
DRL drill mod?
By ldurham in forum Appearance SectionReplies: 3Last Post: 08-22-2011, 06:45 AM -
Drill Mod help
By Chronic442 in forum Manual TransmissionReplies: 11Last Post: 05-16-2008, 12:27 PM -
Drill MOd
By SVG210 in forum Manual TransmissionReplies: 2Last Post: 02-10-2008, 07:01 PM -
Drill Mod?
By Hot Rod SS in forum Manual TransmissionReplies: 3Last Post: 07-13-2007, 12:37 AM -
Drill Mod?
By Hot Rod SS in forum Manual TransmissionReplies: 0Last Post: 07-12-2007, 01:59 AM
