Thread: Antifreeze on the floor
03-27-2013, 06:18 PM #1
- Feb 2011
- Windsor, Ont.
Yellow- 2002 Trams Am CE
Well I checked out the T/A today and found antifreeze on the floor. So I jacked it up and got under it. I couldn't see where it was coming from and the antifreeze was not low. I do store the car from November to may. I'm wondering if it came out through the overflow?
03-27-2013, 06:30 PM #2
- Apr 2010
- Alabama
I would check all of your hoses for leaks and cracks, in case it leaked out of your hoses. If you haven't already that is.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
03-27-2013, 07:25 PM #3
- Jan 2009
- North Jersey
Check your hose clamps as well.
03-28-2013, 04:55 AM #4
If the leak is on the passenger side it MAYBE the heater core.
03-28-2013, 05:15 AM #5
- Dec 2005
- Laurel, Maryland
Water pump gaskets are possible too.
03-28-2013, 05:19 AM #6
- Jun 2011
- Branchville, NJ
When you say floor, do you mean the floor of the car or the floor the car sits on ? If it is the latter than I would pressure check the system. If it is the passenger side of the car floor then it may be a heater core. Is you garage heated ?
03-28-2013, 05:31 AM #7
- Feb 2011
- Windsor, Ont.
It's on the passenger side, and the garage is not heated. There are drip marks on the lower rad hose.
03-28-2013, 05:42 AM #8
- Apr 2010
- Alabama
I would pressure test the whole cooling system to look leaks. I would start looking for the leaks around the lower radiator hose since that is where you said you saw drip marks. How long has it been since you last replaced your radiator and waterpump hoses anyways? If it has been a while you may just want to replace them for peace of mind.
03-28-2013, 07:35 AM #9
How much coolant? little or a lot?
A lot - freeze plugs or major leak in the system
03-28-2013, 07:55 AM #10
- Feb 2011
- Windsor, Ont.
Everything is stock on the car (it only had 40k miles). In the last 2 months it has only dripped about 2 table spoons of fluid.
03-28-2013, 09:13 AM #11
- Dec 2005
- Laurel, Maryland
Mileage doesn't matter here...it's 11 years old.
03-29-2013, 05:36 AM #12
Why do I smell antifreeze?
By bad idea in forum General HelpReplies: 4Last Post: 09-20-2012, 09:57 AM -
Help: Antifreeze smell
By RogerStout in forum External EngineReplies: 9Last Post: 04-11-2012, 09:33 AM -
antifreeze
By V8MUSCLE in forum Almost Anything GoesReplies: 23Last Post: 02-17-2010, 05:32 AM -
Antifreeze...
By guitarjay76 in forum General HelpReplies: 3Last Post: 06-07-2009, 07:27 AM -
Low antifreeze level
By trans.am in forum General HelpReplies: 5Last Post: 03-24-2008, 02:46 PM
