Results 61 to 80 of 94
Thread: E-85 flex fuel who using it????
05-14-2006, 02:47 AM #61
Anhydrous ethanol in the absence of direct exposure to alkali metals and bases is non-corrosive; it is only when water is mixed with the ethanol that the mixture becomes corrosive to some metals.
my arguement in a nut shell,ALL STORAGE TANKS CONTAIN LARGE AMOUNTS OF WATER! ALL fbod fuel systems are bare carbon steel.
05-14-2006, 11:29 AM #62
If that is true then the water and AL will separate from the gas and go to the bottom. I'm going to buy some E85 Mon. I will experiment with adding water and let you know.
05-14-2006, 11:12 PM #63
in central america and parts of south america they are only paying about 12 cents per gallon... Some shit huh?
05-15-2006, 12:52 AM #64
Not true. Not even believable. two years ago ethenol in Brazil was $1.30
05-16-2006, 03:24 PM #65
I mixed 50\50 E85 in my 2000 SS Mon. I new when it made it to the injectors. serious hesitation at mid to high accel. Nothing noticeable at lower throttle positions. The PCM started adapting quickly. At 20 miles I increased the mix to 20\80 E-85. Same problems. Everything fine at lower power but when you floor it there was just very little power up top. My max HP felt like 4,000 RPM. Hesitation and stumbling at RPM over 4000. The CEL only came on at this 20\80 mix and only when I forced the lean condition by running WOT. I topped the tank off with gas. I think I am at a 60\40 mix gas\E85. The car runs normally. No problems and I expect the CEL to go off in the next day. It sucks that E85 is the same price here as gas. Gas mileage results coming in 5 days.
05-16-2006, 06:02 PM #66
- Apr 2006
- south chicago burbs
- 04 srt4 and 99 firebird
Originally Posted by ericwilloughby
05-16-2006, 06:09 PM #67
05-17-2006, 05:12 PM #68
You think he was trying to break his crankshaft?
05-17-2006, 06:43 PM #69
- May 2006
- Warren, MI
Red- 2001 Camaro SS
Oh yeah, run WOT over-lean. The crankshaft will probably survive the hole in the piston.
Anyone wanting to run full out on high percentage alcohol mixtures should get bigger injectors and a full tune/reprogram. Or at least think about what happens to pistons when detonation starts before doing it.
--97T--
05-18-2006, 01:33 AM #70
hmm, ive never heard of putting a hole through a piston, at most i'd expect destroy a ring. only dead motors i know what happened was the crank broke and in an old chevelle, the timing chain broke and the valve hit the piston, making the car have no compression.
oh yea, i had a friend that bought an SVT Lightning with 23000 miles modified, and wound up putting a pushrod through the oil pan. that was 3 days after he bought it, gotta love Ford Racing.
05-18-2006, 12:17 PM #71Originally Posted by goldfingerfif
1. TURBO TURBO TURBO. All you have to do is turn up the boost. Especially if in an LS1 where you are starting off with 10.5-1 compression.
2. If it is cheaper than gas. And the money stays home. US It's only .25 cheaper in Nashville. They are already fucking us here in Louisville, KY. Same price.
As the other dudes were saying. You can use this stuff and explore the limits of your fuel system but you wont get far up the HP scale without spending some money on the fuel system.
Given time I wonder how well the PCM would adapt to mix of E85. I'll never know because is a way out of my way to fill up. And I don't know what is going to happen to the fuel lines and seals in the long term. And I don't have a turbo to utilize the stuff.
05-18-2006, 12:28 PM #72
I heard no detonation. I also run a 100 shot dry with no fuel mods. Full NOS as soon as the peddle hits the floor. It really cranks out the torque but by 4,000 the fuel is maxed out and I get no additional HP over stock. I wanted to raise fuel pressure but learned recently that the regulator is in the tank. Sucks. I have the wet portion of the kit. I really need to install that but I am on here instead. haha. Haven't blown it up YET. This car is much easier to put NOS on than my old 93 LT1. It backfired and blew plastic parts off the intake hoses when it went lean. It had this same NOS kit on it from 40,000 to 140,000 dry. It was still running great the day my girlfriend totaled it and it suffered lean NOS much more than this LS1.
05-18-2006, 12:30 PM #73
Help me out. I want a a\f gauge. Cheap. Should I buy a $40 gauge or go for a $250 scanmaster? What else will it do? If I'm going to spend $250 should I just get HP tunners or LS1 edit?
05-18-2006, 01:25 PM #74
- Oct 2005
- St. Louis, Mo.
Black- 2002 Camaro
Originally Posted by 97PredatorTA
Before people start reaming me saying that theres a specific chemical process that must take place for that to happen, I know this, I majored in chemistry. But still, we are tempting fate for it to eventually happen. And if it only happens once it will still kill tens of thousands depending where it happens. Bottom line is E85 and Gas burn, Hydrogen explodes and under very little pressure let alone the pressure it takes to make it a liquid.
05-18-2006, 01:30 PM #75
- Oct 2005
- St. Louis, Mo.
Black- 2002 Camaro
One more thing..... When gasoline was first being used for fuel, engines were lucky to get a 1/4 HP per cube, and here we are now making over 1 HP per cube. My point is that if E85 goes full scale wich it eventually will and should it would only be a matter of 4-10 years before you would start seeing vehicles getting 30-mpg on this stuff and you would be able to make 800+ horse from only 350 cubes for under $2000.
05-19-2006, 02:24 AM #76
Here is the current gas mileage. Almost no change from gas. The HP is almost the same also. There will not be a big increase.
05-19-2006, 02:39 AM #77Originally Posted by ericwilloughby
If this were to happen at the filling station as some have suggested, you would notice that you are either pumping straight al or straight gas.
05-19-2006, 02:44 AM #78
This is off 60 Minutes within the last two weeks. It doesn't matter how this would translate into US dollars just compare the differnace between the two.
05-19-2006, 03:29 AM #79Originally Posted by myk02k
we wouldnt be getting the hydrogen from the water for fuel cells, to break the hydrogen bonds in a water molecule would require a huge amount of energy
05-19-2006, 03:30 AM #80Originally Posted by ericwilloughby
where's the SS on the graph, would it screw up your Y axis?
Question: 5.3 flex fuel mods
By jimmyz454 in forum General HelpReplies: 7Last Post: 05-27-2014, 02:20 PM -
2009 Ford Flex - Hot Rod Ford Flex
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 08-10-2009, 10:00 PM -
T-top flex!!!
By JoshieDoom in forum Firebird / WS6Replies: 23Last Post: 09-30-2008, 09:56 AM -
Need Fuel Pressure specs for an '02 5.3 Flex Fuel
By Fortune50 in forum GM TrucksReplies: 1Last Post: 09-04-2007, 08:18 AM -
GM Flex Fuel question
By Nastyfoot in forum General HelpReplies: 5Last Post: 08-18-2006, 04:31 AM
