Results 6,581 to 6,600 of 7125
04-28-2019, 08:14 PM #6581
Today no tasks or destinations worth mentioning, but Sunday allowed me to avoid much traffic and therefore have a chance to rev the car up more than usual and have fun with the restored performance after a series of repairs. A Trans Am is meant to speed past other vehicles.
04-29-2019, 03:22 PM #6582
Drive it like it was meant to be driven! Nothing worse than seeing a Lamborghini doing 50 in the fast lane!
Ported/Polished throttle body, Lingenfelter launch module, SLP line lock, QTP exhaust cutout, LS7 clutch, K&N, Ceramic coated longtubes, no cats, 3" exhaust, Flowmaster "B", Eibach springs, Midwest Chassis 9" rearend w/4.10's
05-02-2019, 05:25 AM #6583'02 Black RamAir M6--Kooks LTH, Magnaflo, Lowered Eibach springs and Bilstien shocks, Tuned By Frost, K&N & SLP box, Smooth bellows, polished TB, Spohn perf. suspension, shock tower brace. UMI 3point SFC. Front & side splitters w/ canards. American Racing 18" wheels & Mich. Pilot SS titres
'76 LagunaS3 - 355ci , 350 turbo, 3:55's
05-02-2019, 07:02 AM #6584Spaz is My Mentor
Who needs a reason to pass slow ppl?
05-02-2019, 12:47 PM #6585
Terry, I can totally relate! I'm the same way driving the Ranger...Just let 'em go on by. But in one of my T/A's, uh, I don't think so....Leave 'em in the dust and don't have to deal with them again!! Our cars definitely bring out the race car driver in us!!! It is hard, knowing all that power is just waiting to be tapped into, and not do it.....It's hard to resist!!
05-06-2019, 07:58 AM #6586Senior Member
- Mar 2007
- Henryetta/Tulsa Oklahoma
So I FINALLY tracked down the startup/surging issue on the T/A. Took a fuel pressure tester to it, and found that it would prime to 60, but lose pressure to 0 almost immediately. Pulled the pump and checked the lines (had issues with that when we bought the car), but nothing was amiss. Put everything back together and started up (eventually) to make sure everything was in place. This time, because the car was now warmed up, when I shut off the car, I saw the pressure dropping at a rate consistent with an intermittent hissing sound from the block...injector, pulsing a leak until pressure hits 0...
SO, now I have another issue. I looked up the part number that is on the injector, but apparently it is no longer manufactured. #12561462, I believe these are LS6 28# injectors? Did these come stock on the 2001-02 cars? Anyone have any pointers for a replacement? RockAuto lists a Bosch 0280155931 part number. Looking that up on Google takes me to 0280156211. I know part numbers get updated from time to time, just want to make sure I get the right replacement. Not looking to do anything that requires yet another re-tune of the car. It has the V2 cam, but stock LS6 intake and stock 241 heads, so I don't think I need to move up in size on the injectors. I'll take any feedback at this point, just ready to get this gremlin behind me. Probably do an oil change too, in case fuel got down in the oil and thinned it out. This has been a problem for a while now, just getting way worse the last few weeks.
05-06-2019, 09:16 AM #6587Spaz is My Mentor
I believe those are the correct injectors.
05-06-2019, 10:01 AM #6588Senior Member
- Mar 2007
Ordering all 8, $432. Worth it to solve the issue once and for all.
05-06-2019, 10:26 AM #6589Spaz is My Mentor
you sure you needed all 8?
6.0L Block - Forged 403ci
, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
05-06-2019, 12:44 PM #6590Senior Member
- Mar 2007
Not totally sure, but I'd bet so. This car still had a stock fuel filter on it when I bought it at 92k miles. I'd be willing to bet it never had any fuel injector cleaner run through it the entire time the previous owner had it. It sat for a while before I bought it too. That and I just don't feel like messing with it more than once. Might as well do it while the money's in the bank, ya know?
05-06-2019, 12:56 PM #6591Spaz is My Mentor
you just get this one?
05-06-2019, 01:09 PM #6592Senior Member
- Mar 2007
No it's the same one we've had. The problems are just starting to really bubble up. I saw and replaced the fuel filter within the first month, should have been my first sign of things to come.
05-12-2019, 11:15 AM #6593
Guys,
Wanted to let you know a few days ago but i have had log on woes due to forgetting my password
and PAjeff was on the case to try and help but i managed to find it.
But... to my point... I collected my replacement sail panel from the painter on Friday and it is a really good
job with flatting right up to 4000 and then machine polished to a zero peel finish.
Very pleased and although the replacement of these panels has already been documented, i will certainly
do it as anything that may help anybody can only be a good thing!
05-12-2019, 05:19 PM #6594
05-13-2019, 09:34 AM #6595
Not yet Don,
I have the panel positioned carefully indoors (!) with a blanket over it and i will take all those lovely pics when i get busy with the swap
during our half term which is in about three weeks time.
05-13-2019, 01:05 PM #6596
Awesome! Can't wait to see it.
05-13-2019, 01:56 PM #6597Senior Member
- Mar 2007
Injectors got replaced this weekend. Pressure now holds like it should, and the car (so far) starts up like a champ every time. Next on the list, the steering rack, then onto tracking down a slow leak at the right rear axle (probably the seal). Gotta love aging vehicles.
05-14-2019, 01:54 AM #6598
^^ Your fuel pressure was bleeding off? Mine has done that forever now and I am wondering if it is a leaky injector as I have not been able to find any other issue.
05-14-2019, 05:17 AM #6599
05-14-2019, 05:43 PM #6600
You replaced all of the injectors?
There are currently 8 users browsing this thread. (0 members and 8 guests)
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
