Results 41 to 60 of 90
Thread: LQ4 Turbo Build Thread
07-18-2012, 02:41 AM #41
Great progress! Looks awesome!
I'm working on another motor myself..
07-20-2012, 10:19 PM #42
Just picked up an LS6 Intake today!!!! the thing is MINT!!!!
07-21-2012, 07:38 AM #43
Nice find!
07-31-2012, 06:25 AM #44
Ordered a GodSpeed GT45R Turbo...
Specs:
Intake :4 inch
Outlet: 2.5 inch
Compressor trim: .70 ar
Compressor Wheel diameter: 66.71 /84.20
Turbine wheel diameter : 63.56 /73.60
Exhaust trim: 1.00ar
Turbine flange type: t4 flange
Downpipe flange type : 3.25" v band flange
Cooling type: oil cooled only
07-31-2012, 06:28 AM #45
08-01-2012, 02:30 AM #46
- Oct 2009
- pasadena md
- Blog Entries
- 2
Black- 2002 SS Camaro
Nice look can't wait to hear the thing spool up
2002 Camaro SS Black Betty
Suspension:
Poly Trans mount, Solid Motor mount, Strut tower Brace
Performance:
SLP intake, Smooth Bellow, A.I.R Delete, M/T's on Salad Shooters
Apperance:
Re-Badged, Ultragauge, Whistler Mod, Racing Seats, Auto Hurst Shift Handle
08-21-2012, 04:59 AM #47
- Aug 2011
- Browns Mills NJ
Green- 1995 Z28 w/ LS1 Swap
Looks like a sweet build, cant wait to see the finished product
09-04-2012, 05:16 PM #48
Got some More stuff...
Mishimoto Intercoler
And started fabbing up my hot side!
if anyone knows anyone with 80lb injectors at 3bar i am interested.
Also looking for fuel rails
09-04-2012, 05:17 PM #49
New shiny stuff! Keep the pics coming, please.
11-03-2012, 08:15 PM #50
Sorry for the bad updates its been rough!
One step forward two steps back! So I got the LQ4 fully put together and me and a buddy swapped it in a weekend. I spent about 30 minutes getting it to run and idle in the driveway. So me and my buddy took it for a test drive everything was good till I looked down at my gauges and and I went from 70psi of oil pressure to 10psi so I got her back home and changed the oil and it came out silver So the swap begins again! Pulled the LQ4 out got new head gaskets and oil pan gasket and put the heads cam and intake on the LS1 to go back into the car!
I haven't looked far into the LQ4 yet but Numbers 3,7,and 8 rod bearings are Destroyed along with the crank journal... YAY!
LQ4 Swap
LS1 OUT!
My Buddy
LQ4 Going In
Getting Ready for First Start
finishing final steps
LQ4 is back out again YAY!
LS1 back in and running!
Video^^^^Last edited by My00Z28; 11-03-2012 at 11:53 PM.
11-03-2012, 11:11 PM #51
Looks good cant wait to hear it!!
11-04-2012, 10:22 AM #52
Any idea what happened?
11-04-2012, 12:23 PM #53
i didnt resize my rods after the arp bolt install and i think it egg shaped the rods...
11-04-2012, 08:10 PM #54
11-04-2012, 08:47 PM #55
The arp bolts have a higher torque spec than factory bolts when they got torqued down it misshaped the rod ends and caused the clearance to be to tight in the centers and too loose on the sides. You resize them to the bolts when they are fully torqued you pretty much hone them out to have a bigger bore so till they are round again!
11-04-2012, 08:49 PM #56
My stupid mistake cutting corners I guess and I paid for it. But I learned a new life lesson...
11-05-2012, 09:11 AM #57
11-05-2012, 03:18 PM #58
- Mar 2011
- Waynesboro, Pa
Mystic Teal Metallic:320c- 1998 Camaro Z/28
ok thanks for the explanation looking forward to more progress on this build
11-05-2012, 04:18 PM #59
Block is fine crank is scored pretty bad and rods are fine so that's a bonus I guess the next build for that motor will probably be a fully forged 370!
11-05-2012, 08:50 PM #60
Let me get this straight.
With ARP bolts for the Connecting rods I will need to have them torqued to specs, then have a machine shop "re-size" them for proper clearance correct?
I ask because I have found a place that will cryo-treat an entire engine for $450. Reading the literature and it seems this is what some NASCAR, INDY, and some other motor sport teams are doing to their engines. Gives them much more engine life and makes them much stronger.
I won't say it makes it bullet proof but will make it much better then stock.
Lq4 turbo build
By 91lq4camaro in forum Forced InductionReplies: 4Last Post: 05-20-2019, 07:42 AM -
Turbo build help
By 200z28ss in forum Forced InductionReplies: 2Last Post: 02-19-2012, 04:11 PM -
My turbo ls2 build
By blackmagicturbo in forum Camaro / SSReplies: 68Last Post: 06-15-2011, 06:26 AM -
Turbo V8 Build
By SmallBCS10 in forum Forced InductionReplies: 2Last Post: 06-08-2011, 01:21 PM -
turbo ls1 build
By turbols1317 in forum General HelpReplies: 27Last Post: 09-27-2010, 08:40 PM
