Results 41 to 60 of 149
Thread: Going up against a Evo 9?
11-09-2006, 11:27 PM #41
- Sep 2005
- Bakersfield/Long Beach Ca
YJ- 04 GTO M6
It all depends on your rim size, if you have the 16 by 8's im not really sure but the 17 by 9's can get 315's put on I think.
11-10-2006, 02:16 AM #42
I have 16's x 8
11-13-2006, 05:38 AM #43
- Nov 2006
- palatine IL
All you need is slp exhaust and a set of drag radials and 12.9 with an auto can be yours.
11-14-2006, 06:27 AM #44
What else do you need to do besides change the rear gears? Does the computer accept the change? What about speedo calibration? I'm asking because I have 2.73's and I want 3.42's.
11-15-2006, 11:06 PM #45
- Feb 2006
- SOCAL
Black- 08Corvette C6/07BMW 328i
The Evo 9 with just exhaust, intake, fuel pump, boost controller and a good tune on race gas on 27psi is capable of 11.7-11.9 at around 112mph. I own one and I can tell you it will run this numbers with the right driver. Be very careful. Evo 9 is much faster than a Evo 8 so I would not play with it.
11-15-2006, 11:39 PM #46
- Sep 2005
- rochester,ny
pewter- 2001 z28 lingenfelter 383
ive noticed that its much faster as well.......the numbers on vishnu's site show this as well..........but y does it take to mods SOO much better than the 8????? maybe u can explain cuz i have been wondering..i know it has the mivec system similar to vtec.....does that have somthign to do with it?
11-16-2006, 12:34 AM #47
empty all the trash from your car, spare tire, glove dept, papers CDs etc...all the extras.. it gets 50-60lbs off, wash the car the night before, there's sand and dust that weights 10-15lbs, also have no more than 1/4 of tank at the track, get some air out of the back tires, u get more contact area and more flat for the track,, finally, if u got A4, at the track have left foot on brake and right rev it up 4-5k and floor it at 3rd yellow light.. practice the take off,,,
11-16-2006, 12:26 PM #48
- Oct 2006
- Seaford
Black- 2001 Trans Am
under the hood of your trans am, if its a 98-02 model, look where the intake for the ram air is, there is a big piece of plastic which is blocking incoming air, drill the rivets out and take that piece of shit out of there, when i did, i got another pound per minute of air, which translated takin me from 13.1-2 to 12.7-8
11-16-2006, 12:47 PM #49
i got the SLP cold air inducted from underneath. don't need to spend $800 on a hood.. and I do look like stock, yeah nice surprise when I whoop them
so get the SLP cai, lid and filter. $300 all together and you'll gain 10rwhp.
11-16-2006, 05:59 PM #50
- Feb 2006
- SOCAL
The Evo 9 comes with MIVEC which is like VTEC and also the turbo is bigger. It also has water running through the head which allows for more boost than the 8. The MIVEC makes the turbo spool much faster. My Evo with Turbo Back exhaust, Intake, Manual Boost Controller, Fuel Pump and a Tune. With 110 Oct Gas and 27psi I ran with my friends 98 Camaro SS with Cams, Ported Polished Heads, Lid and Full Exhaust, 410 Gears and a Tune. On top end 60-140 and I pulled on him on 3rd, 4th and we were dead even on 5th.
11-16-2006, 06:25 PM #51
- Sep 2005
- rochester,ny
wow sick......but 110 oct gas??? how much more hp does that get u over 94 oct??? has to cost u a fortune
11-16-2006, 06:40 PM #52
rip him a new asshole!!!
11-16-2006, 06:56 PM #53
- Feb 2006
- SOCAL
11-16-2006, 07:14 PM #54
- Sep 2005
YJ- 04 GTO M6
I think its time for you to get yourself a bigger turbo, your almost maxing out the boost arent ya?
11-16-2006, 11:02 PM #55
if u wanna do gears change from 2.73, do 3.73 if u are A4 or 4.10 if u M6.
but u need to recalibrate the speedo using a handheld programmer like HyperTech 3, or heck do a pro tune at a dyno shop. otherwise your speedo will be way off,
also do torque stall converter, the gears will let u accelerate faster and the stall will
do a torque multiplier.. u smoke hiz asz.
11-16-2006, 11:55 PM #56
- Feb 2006
- SOCAL
11-17-2006, 12:01 AM #57
- Sep 2005
- rochester,ny
start with a 02-04 z06 instead.....if your looking to build a monster is a much better platform than an fbody
11-17-2006, 05:23 AM #58
neah, too much money, just get 01-02 ws6 (ls1) since it uses the ls6 intake manifold already, and it has an above average exhaust system already, then do a ls1 to ls6 motor swap. that way you got the ls6 heads/cam.. u can just port those heads and ur cool, then slap a supercharger..
that should put u 550 to engine spending as much as u woud buy a c5 z06 but 150 more hp at flywheel...
11-17-2006, 09:59 AM #59
- Sep 2005
- rochester,ny
what about corners? and braking?? lol
11-17-2006, 12:25 PM #60
