Results 41 to 60 of 196
Thread: Best Mild Cam for DD ls1???
07-18-2007, 02:04 PM #41
07-18-2007, 02:14 PM #42
- Oct 2005
- RI
Mag Red- 2002 Vette
I would personally steer clear of the 918's unless you know the batch number and speak with Comp first. They switched vendors and had issues with the springs when they did, some didn't even last 50 miles before breaking. There are other, better options out now in the beehive spring design.
QTP headers, Katech timing chain, GMPP damper, VHP 056 cam, Crane 1.7 rockers, Dart 205 heads, ATI balancer, Callaway Honker CAI, Shaner TB.
07-18-2007, 02:17 PM #43
07-18-2007, 02:23 PM #44
- Oct 2005
- RI
Mag Red- 2002 Vette
Here is how I understand things. PAC Spring used to make the 918 for Comp. They switched to a new vendor last fall and there were several bad batches that hit the street. The internet is littered with guys who had them bust, some lucky enough to have them break when the car was idling other lost a motor. PAC Spring also sells two beehives, one that is nitrided (1518) and one that is not (1218). The nitrided would be a better long term spring, but is a little more money. Crane is also now carrying a beehive spring, which by the way is made by PAC spring, and is the same as the 1218.
PSI also makes a killer beehive spring, the 1511. This is the spring that Katech selected after a lot of spintron testing for the LS7 setups.
Do some research, Comp is taking care of the problem but there are a lot of guys out there who had them break. I have lost confidence in them myself and wouldn't use them at this point.
07-18-2007, 02:29 PM #45
- Sep 2006
- Baltimore, MD
Red- 98 Z28
07-18-2007, 02:38 PM #46
07-18-2007, 02:49 PM #47
- Sep 2006
- Baltimore, MD
Red- 98 Z28
07-18-2007, 04:07 PM #48
- Dec 2002
- n/w chicago
a few bolt ons, 379 rwhp
11.96 @113.25
07-19-2007, 03:34 AM #49
I'm getting this cam with 581 lift and 112 lsa, and the guys I'm buying it from also suggested stage 2 ported cnc 59cc heads. Does this sound like a good combo? The guy was saying it would put me over 400 to the wheels plus the dyno tune I'm getting.
07-19-2007, 05:37 AM #50
07-19-2007, 05:38 AM #51
as long as you have a Lid, LT's and a catback system. you already have the Ls6 intake, so you should hit around the 400rwhp mark w/a good tune w/that H/C combo...
its the same combo that i currently have and im putting down 409/388. just remember, every car is different. you might make a little more, or a few ponies less. but dont be discouraged...
07-19-2007, 06:16 AM #52
well i have the k&n fipk, hooker lt's and y pipe. i'm just looking for a few more hp to push me into the 11's. thanks for the input
07-19-2007, 08:48 AM #53
- Jul 2006
- indiana
black, 05 Roush- black, 99 T/A WS.6
Your car will definately be capable of 11's it just a matter of hooking up and getting a good launch.
1999 T/A WS6 Black -------SOLD
05 mustang Roush sport;
DOB manifold, m122 SC, 47lb injectors, gt500 TB, roush TVS CAI, Detroit rocker SC grind camshafts, Mac LTs, off road x, roush off road mufflers, roush short throw shifter, kenne bell BAP, Brenspeed 93 octane tune. 479rwhp 436ftlbs SAE.
07-20-2007, 05:39 AM #54
I'm looking for under 2.0 on 60'. I'm researching another clutch to put on it as well.
10-04-2007, 11:34 PM #55
- Sep 2006
- Baltimore, MD
Red- 98 Z28
10-06-2007, 08:01 AM #56
- canada
nice
10-07-2007, 03:57 PM #57
10-08-2007, 12:25 PM #58
- Oct 2007
- australia
white- 2000 hwaypatrol commodore
higher lift +more duration + tighter lobe centres gets you the more peaky performance
lesser duration +wider lobe centres with bring it back to linear+smooth.
there are cams and there are cams for an a4 with standard converter ls1 204 @50
should be the bare minimum atleast.
the old man cam might be the ticket.
10-08-2007, 12:30 PM #59
- Sep 2007
- Denton, Texas soon Lafayette, Louisiana
Blue- 2002 Z28 Camaro M6
I have been eyeing this cam lately. Still need to do alot more research on them. Think it would be to big for a DD that sees lots of miles ?
http://www.texas-speed.com/shop/item...d=167&catid=44
10-08-2007, 12:41 PM #60
That cam isn't that big really. 228 at .050 is mild in my opinion, and you can even spread out the lobe seperation to 114 or more and smooth it out quite a bit, with a good tune, someone that knows what they are doing can make that cam disappear and sound stockish. It also depends on how you degree the cam as well, and whether there is any advance ground in already. Advancing the cam will help to smooth the idle as well.
Looks like a great daily cam to me. My daily ride runs a 240 at .050, and it only has a slight lope with a sharp tune on it, and installed 4 degrees advanced.
It all depends on what you call streetable, some people have a low tollerance for anything other than baby butt smooth.
some mild entertainment.... lol
By suede in forum Almost Anything GoesReplies: 67Last Post: 03-12-2011, 06:30 AM -
Help: What gains can i get with mild cam?
By mglangley21 in forum Internal EngineReplies: 24Last Post: 01-10-2010, 02:50 PM -
Mild Knock
By robert 98 in forum General HelpReplies: 14Last Post: 06-04-2009, 04:57 AM -
looking for a mild cam
By 00maroz28 in forum Internal EngineReplies: 15Last Post: 06-18-2007, 07:08 PM -
mild cam horsepower?
By 69camarokid in forum Internal EngineReplies: 1Last Post: 12-05-2006, 10:56 AM
