Results 41 to 60 of 70
Thread: Getting pissed off!!! (video)
05-12-2010, 04:56 PM #41
- Feb 2010
- Abilene Tx
White- 1998 FireBird Formula
and if anyone has one or knows where i can get one, i need one of the clips that holds the air filter lid down
05-12-2010, 07:11 PM #42
+2, I managed to loose one of mine too..
05-12-2010, 07:14 PM #43
- Feb 2010
- Abilene Tx
Just found out you can get them from
the dealership for around $10. I'm gonna call
them tomorrow and find out, I'll let you know
05-13-2010, 05:43 AM #44
05-13-2010, 02:25 PM #45
- Feb 2010
- Abilene Tx
the chevy dealer here in town told me they are $4.68 a peice.
05-13-2010, 02:33 PM #46
I use a small cable tie to hold the clips in the close position.
05-13-2010, 02:38 PM #47
05-13-2010, 02:50 PM #48
05-14-2010, 01:50 PM #49
- Feb 2010
- Abilene Tx
Just bought a 98 wiring harness and a Vig 3200 stall that comes with a free restall.. can't wait to get the stuff here!!!!
05-14-2010, 04:19 PM #50
- Jan 2009
- North Jersey
Uh-oh...someone got bit by the mod bug.
05-14-2010, 04:26 PM #51
- Feb 2010
- Abilene Tx
trust me i got bit a while ago just haven't had the money to do anything. We finally got part of our income tax check in so i decided it was time for the stall next will probably be a cam
05-15-2010, 06:00 PM #52
- Feb 2010
- Abilene Tx
alright guys need some help again, i only got to mess with the car for about 2 hours today and i was hoping to get the motor completly out but it didn't work out that way. Anyways i am down to just the driveshaft, gear select linkage and then unbolting the k and cross members..
How do i go about disconnecting the driveshaft and that linkage? step by step would help, never messed with any of that stuff before..
05-16-2010, 03:57 AM #53
- Apr 2008
- Madison, WI
unbolt the driveshaft from rear end, pry it off the rearend yoke, and slide it out of the transmission
Auto or manual?
05-16-2010, 07:37 AM #54
- Feb 2010
- Abilene Tx
its an auto
05-16-2010, 09:38 AM #55
- Apr 2008
- Madison, WI
ok then the shifter cable just unsnaps from the trans lever. Just pry on it with a screwdriver or something. then unbolt the cable bracket and the shift cable is free
05-16-2010, 10:30 AM #56
- Feb 2010
- Abilene Tx
sweet, thanks man!!
hopefully i will have the motor out here in a couple hours, gotta wait for the youngest son to lay down for a nap...
05-16-2010, 03:26 PM #57
- Feb 2010
- Abilene Tx
UGHHHH!!!! i was really hoping to have this thing out today, after some minor issues and set backs, all i have left is getting the damn torque arm off, which i can not get off for the life of me!!
everything is unbolted, i started lifting the car when i noticed the torque arm, i got the bolts out of the back of it earlier and i guess just forgot about getting it off of the trans. SO does anyone have any tips to get this thing loose from the trans? it looks like it just slides in but it damn sure won't just slide out.. I plan on getting that disconnected tomorrow when i get home from work then getting the motor out, shouldn't take to long after i get that off since it was coming out nice and smooth with no other issues...
05-16-2010, 04:17 PM #58
I had to remove the torque arm recently. At the transmision housing were the torque arm meets there is the actual bushing and it's bracket. There are 3 bolts that hold the bracket in place. The bolt on top of it holds the 2 parts of the bracket together. If you loose the top bolt off then you have to move the loose part of the bracket until you can get it out. You might just be able to loose the bolt just enough to just slide the torque arm out.
05-16-2010, 05:13 PM #59
- Feb 2010
- Abilene Tx
I'll give it another shot tomorrow when i get home from work. I just talked to a buddy of mine that said basically the same thing, he said it should just slide out with a little force if not to loosen those bolts that are on the trans itself... we will see, i still have till wednesday or thursday before all my parts should be here anyways...
I can't wait to get this stall put in, just got a trans cooler to go with it.
05-16-2010, 05:45 PM #60
Make sure that the bushing is good and not broke. I replaced mine with the Poly one. I want to get the relocation bracket so I can disconnect the torque arm from the transmision.
I'm really PISSED!
By blackSS01 in forum Almost Anything GoesReplies: 20Last Post: 05-06-2010, 12:22 AM -
I'm pissed
By Danger731 in forum Western MembersReplies: 20Last Post: 11-02-2008, 04:54 PM -
just pissed off.....
By pewterzron in forum Almost Anything GoesReplies: 15Last Post: 01-15-2008, 03:50 PM -
Done and Pissed
By Knighthawk LS1 in forum Rocky Mountain MembersReplies: 22Last Post: 10-25-2006, 03:15 PM -
Watch this video. I'm a little more than pissed off right now.
By nitrox28 in forum Political / Debate ForumReplies: 14Last Post: 03-31-2006, 03:37 PM
