Results 41 to 60 of 66
Thread: Engine ticking
06-14-2011, 02:44 PM #41
usually glass is the perfect surface
06-15-2011, 04:24 AM #42
I have an 01 Z28 (Sara) garage queen with 28K original miles, and I have had a low uneven tick (can hear it more @ idle) since 8k. I have no adverse problems with the vehicle, have plenty of power, and throw no codes. I run 10W-30 synthetic oil.
SteveC
06-16-2011, 02:22 PM #43
I have the same exact ticking, sounds louder under the car but when listening from engine bay its loudest at the drivers side rear of the motor. Which after doing countless searches I think it has to be the oil pump o-ring making #7 lifters do the ticking. I pullled all the rockers and push rods to check for straightness, all checked out good and I put assembly lube on the rockers. When I started it there was no ticking for about 1 minute then started again. Its very irritating.
06-16-2011, 02:49 PM #44
06-16-2011, 06:46 PM #45
To the OP- if you change your oil every 1000 miles (Did I read that right?) you really don't need synthetic oil IMHO. I got 300K + miles out more than one GM vehicle using conventional oil. As far a noise- I think the aluminum block/heads amplify engine noise and it may just be me but synthetic oil seems very thin when compared to the same type (10/40 etc.) in conventional oil.
I damn sure wouldn't be pulling out my oil pump when the car has good pressure..... maybe that's just me. Then again- I can't really tell how loud your car is...
06-17-2011, 10:57 AM #46
Thats why I haven't pulled out the oil pump yet. Then if i did pull the pump and the ticking was still there i would be really pissed. If you want to know how loud it is. Take a motor with adjustable rockers and loosen one of the rockers till it klacks and put the valve cover back on lol.
06-17-2011, 05:45 PM #47
06-18-2011, 04:15 PM #48
- Sep 2010
- Farmington Hills, MI
Navy Blue Metallic- 2002 Trans Am WS6 NBM
I know this might be elementary for you guys, but what exactly is piston slap? I have ticking as well that I am trying to get rid of. When I searched out the sound, I found it was coming from my injectors. Could some one give me their opinion on what I could check for and or what I could do to get rid of the sound. I used fuel injection cleaner, but the sound didn't go away.
Diablo Sport Predator Performance Tune | TB Bypass | Bilstein HD Shocks | Eibach Pro Kit | UMI SFC | UMI Rear LCA's and brackets | UMI adj PHB, UMI Front/Rear Sway Bars |UMI Strut Tower Brace | SLP Lid | SLP Loud Mouth with quad tips | High output alt
06-18-2011, 08:17 PM #49
I'm not an expert, but injector ticking is all together a different sound. i really can't say i have not listened to your car, but personally i find it harder to listen and pinpoint where a noise is coming form, and some one did point out that its also harder on an aluminum block, and i agree. if I'd have to take a stab at your ticking and you think its near the injectors, i would look at your rocker arms and valve springs, there known to make a little noise. but, piston slap is form the piston rocking in the bore when the piston changes direction the skirt slaps up against the bore. can be a tolerance issue or caused from short skirt pistons.
06-19-2011, 05:56 AM #50
06-19-2011, 06:18 AM #51
Stock rockers have been known to spit out their needle bearings which will then either lay on top of the head or drop down into the oil pan.
06-19-2011, 06:51 PM #52
- Sep 2010
So is it a complicated job to install new rockers or springs?
06-19-2011, 07:12 PM #53
- Jan 2009
- North Jersey
I might be missing some steps, but I believe the install is pretty straight forward...it's the torquing down the rockers and adjusting the lash to spec that can me a PITA. But if you know what you're doing, everything should be cake.
06-19-2011, 08:07 PM #54
- Sep 2010
There is the catch," if you know what you are doing". Lol. I know my way around my tools, but don't know much about internal engine, yet. Think the factory service manual will explain how to do it? If I just switched them out even if they were good, will I benefit from after market rockers?
06-19-2011, 08:34 PM #55
- Jan 2009
- North Jersey
A factory service manual should help. It will give you torque specs and lash settings.
06-19-2011, 08:39 PM #56
06-20-2011, 04:51 AM #57
You need two special tools to change out the springs: 1) An air adapter that screws into the spark plug hole and attaches to your shop's air supply. This keeps the valves raised as you remove the retainers and swap out the springs. 2) A tool to compress the springs on the head so you can remove the locks. I see that Jeg's now lists one in their tool section for the LS1 heads.
06-20-2011, 07:09 PM #58
06-20-2011, 07:12 PM #59
06-20-2011, 07:24 PM #60
- Jan 2009
- North Jersey
If you follow Jeff's instructions, and you don't pull the heads, there shouldn't be an issue.
Need Help - engine ticking sound
By Flash00TA in forum General HelpReplies: 14Last Post: 08-25-2013, 02:39 PM -
Question: Warm engine ticking
By kensz28 in forum General HelpReplies: 5Last Post: 04-28-2008, 03:53 PM -
ticking sound from engine??
By 1stgto in forum GTOReplies: 14Last Post: 06-14-2007, 09:13 PM -
Ticking from engine can't find cause.
By traceymccabe in forum Internal EngineReplies: 31Last Post: 05-01-2007, 03:47 PM -
Engine Ticking now, any suggestions?
By Mike's TA in forum Firebird / WS6Replies: 2Last Post: 12-14-2006, 06:47 PM
