Results 41 to 52 of 52
01-06-2015, 04:38 PM #41
Nicely done.
04-28-2015, 04:08 PM #42
UMI Performance G-body frame brace - Hot Rod Regal
Pretty cool little frame brace from UMI Performance...
I installed it and made a quick video in the link... I think this will help stiffen the rear frame rails on the g-body...
-Matt
08-12-2015, 07:07 PM #43
Trying out the complete Hotchkis Sport Suspension Stage 2 TVS kit. Got some install videos and a few pics here - Hotchkis Suspension for the G-body
also using the Baer Brakes bumpsteer kit - they look good together
08-13-2015, 02:44 AM #44
Will check out this vids and pics this evening. This is going to be one well built Regal!
08-13-2015, 06:17 PM #45
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
It is pretty sad that it took about 20 years before manufacturers paid serious attention to G-Bodies. When I had my '86 Cutlass, there was nothing out there for them, then they figured out how good the cars were and that people would spend their money on them. I'm jealous of you guys
09-13-2015, 03:51 PM #46
01-04-2016, 05:04 PM #47
Thanks for the complements guys!
I am really amazed at how many cool parts are being developed for the G-bodies and how many pro-builders are treating the platform like the classic A-bodies! Its only good things for G-body guys! Truly though, if one thinks about this recent revolution, I would say the age of the guys building them has a big part of that and the use of the LS engine.
SO... one of the common problems with GM cars is the tilt column tend to wear out in the older cars.Talked to a few guys with bad tilt columns in their G-bodies. Another scenerio, I had a column shift column for my G-body originally and swapped to a floor shift column. but there is a shifter linkage on the stock columns that is not used when using an electronic transmission (4L60e/4l80e). So my solution to these problems was a quick remedy from Ididit Inc. (click link for article and pics)
http://hotrodregal.com/ididit-univer...eering-column/
It's an option that not many G-body guys want to try since we have excellent columns usually... But what if you want something a little more crisp feeling than the stock column? Or (like my situtation) if you have a column shift car and want to switch to a floor shift column? Or if you just have a worn out stock column with a sloppy tilt...a Ididit Universal column or a custom built column is a good option.
hope this helps!
Matt
01-22-2016, 02:14 PM #48
So I help out on another car build a little...
Greg Cragg's LSX El Camino and the Ridetech suspension install (part 1)
LSX El Camino is riding with Ridetech! - Hot Rod Regal
This car has what I need on the HotRodRegal!
11-16-2017, 04:57 PM #49
New shop, New El Camino >>> HolleyFest2017 - SuperChevy Gateway
built a new shop... Buddy Greg has a new El Camino- worth a look - Regal is up next.
11-17-2017, 03:19 AM #50
Very impressive on both counts! Congrats!
12-01-2017, 05:38 PM #51
thanks Jeff! just work'n
02-10-2018, 02:05 PM #52
Greg Cragg's new El Camino engine specs are up. Hp and tq numbers of the Mast Motorsports LS3 416ci
Mast Motorsports LS3 416ci stroker engine - Hot Rod Regal
currently working on frame modifications on both cars... so they are blasted apart again (go figure). Always striving to be better than our last rendition.
build 1 my 88 mazda rx7 ls1 swap
By SS Shaun in forum LSx Retrofit and SwapReplies: 21Last Post: 09-05-2012, 07:07 AM -
Question: Lt build or ls swap
By Wes97ta in forum Internal EngineReplies: 9Last Post: 10-11-2011, 04:45 PM -
LS6 SWAP and build with pics
By redbird555 in forum Internal EngineReplies: 18Last Post: 05-31-2011, 03:31 AM -
LS1 SBC 4.8l HighPerformance Build/Engine Swap
By AdvancedDesign in forum General HelpReplies: 0Last Post: 10-12-2010, 03:10 PM -
LS1 swap or build up LT1
By darkass300 in forum General HelpReplies: 17Last Post: 05-07-2006, 08:55 AM
